As above I have a 2001 2wd ford courier and a mate has a written off bravo 4wd ute it's an 03 or 04 model but practicly the same .same engine etc but it's 4wd turbo diesel not 2wd .
My question is I know the courier is a bravo rebadged but are the 4wd and 2wd chassis the same ?
Can I make my 2wd courier a 4wd? I have looked and everything looks pretty I identicle
A couple of engine differences but I'm not interested in the bravo engine.
I wanna bolt my engine to the 4wd box then bolt it in my car ?
Would the ecus be different ?
Any much appreciated
Cheers
The courier is 2x4
And the bravo is 4x4 int not constant awd or anything just Low and high range etc
I've been looking at it a lot today only things I can see that may be an issue is the torsion setup on the courie is slightly different but sits in the exact same position on both vehicles .
And the gear box crossmember sits in a different position which is easily over come
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
