Hay guys iam either importing or buying a 180sx
iam looking at a 94 type x white proberly with good exhuast good aftermark suspension and lsd if poosible =)
a good car with not to many km on it =) about no more than 90,000
iam willing to spend 17 k on road.
now i will proberly be importing one with craig but while iam saving iam just looking around here to see if i can find somthing special hehehe
i just wanted to kno when looking to buy a 180sx what should i look for e.g things that can go wrong or things in the engine like turbo etc.
how can u basically tell if its a good car. =0
if i do buy one from here i will be bringin my mate he a performace mechinc so he knows also but what about body wise i herd afew poeple say ohh what happends if chacsi bent etc
how can u find these things by just looking at a car =)
hope you guys can help me =)
and if you know any one who is selling em for a good price let me know hehe =)
Thanks =)(
https://www.sau.com.au/forums/topic/3992-what-to-look-for-when-buying-my-180sx/
get the champagne colour man its truely sex!! :)
for 17k u should be able to get one with some nice mods on it... i was going to bring in a 94 Type-X which was going to cost me 12k inc everything but rego... it had a few nice little mods but nothing too drastic... for 14k landed and complied i could have had one with lots of mods and a nice kit.
im sure that by using craig u will be able to rest assured it isnt going to be a lemon and if it is he will be able to look after u.
A piece of equipment used to aline the chassis rails after a nasty hit.
It is possible to confuse marks with some type of marks left by normal jacks.
If you see little divot type marks all the way along the chassis rail it probably a better chance then not a chassis straightener. ouch!
They use it also to check the chassis aswell, so it might not of been "pulled" back into true if you see them...
most 180s are pretty old... check for rust... crimp marks are a very important pointers for ex drift cars. Also spot welds on the panel interior (best ones to check are the guards front n rear)
SR20DET is absolute class... mine was a CA18DET which is slightly tamer and older... still managed to get near 160 rwkw after a bit of engine tweaking and modifying.
If you find one that looks like its had brace pads on the interior it means its had a hard life as a drifter.
If you can try n get one that has full logs or a service history at least.
Stay clear of Sil80s and onevia's most of them are trashed.
most of the controls ont he interior are on stalks n stuff, make sure they're not broken coz the controls can be a bitch to hunt down (from experience)
Check the axle's for stress fractures etc.
Check firewall to see if there's any dents etc, if there are it usually means the car's been in a pretty bad chassis damaging accident.
Other than that they are usually prone to bodgy audio installs by their owners with faulty or loose wiring (not critical thing to look out for).
Everyone's gettin a 180 these days, I'm regrettin havin sold mine now... :D Had the strawberry face kit n all
I payed close to 5.5k a year insurance (I only had it for 7 months) thru Shannons under my old man's name. Altho the base quote was $2400 with 10%NCB 19 yr old (me!!!:D) This was for a garaged car kept in Epping, NSW
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
