as rob posted, it's been covered, but as i say in EVERY fuel economy thread, don't just post up how many kms you are getting before you fill up. calculate it into L/100kms otherwise it means absolutely nothing in terms of fuel economy. what you are classing as a tank full may be 20L different to what someone else is, so the actual economy you are getting will be drastically different, but the distance between fillups will be the same. if you don't put it into fuel economy terms then you won't get accurate answers.
I used to get around 10l/100km pretty easily when i used to travel on the fway alot in my skyline.
these days with a fair bit more driving closer to home and in slightly busier traffic im gettin about 11-12L/100km - still pretty decent imo, the fuel consumption doesnt bother me too much at all!
if you mean you get 350-400km out of a full tank thatd be around 15? I think we have a 60 or 65L tank.
If you're driving harder that'd prob be about right .. I'm a bit of a granny on the roads.
it's that bad?! I get 12.4 l/ 100 avg (mixed highway and street driving) from a 6L V8 lol, and i dont go easy on it. I would think you should be getting at least 500km a tank / MAX 10L / 100 on a N/A skyline.
they are a pretty highly strung engine. that's why their economy sucks donkey balls for a 2.5L engine. gearing isn't that much worse than any other small engined car. they don't have the torque to run tall gearing like bigger cube engines. if they did have tall gearing then they would be shockingly slow (in the same way that if falcodores had shorter gearing they would give mildly modded gtst's a run for their money).
more stoker kits for big block V8s than there is Jap turbo motors
From memory it was a rego/tax thing in Japan, small engine means less $$$ to register = more appealing to buyers
Quite true . . .new stroker kit out for toyota 4AGE available now
they have the same thing in singapore .. most cars there have smaller engines than the same car here.
I believe lancers have a 1.6 there whereas we get a 2.0, same with alot of other cars!
haha .. amusingly HSV's cars have started to be sold in singapore!!
Prices start at 268,000 SGD for the Maloo, and up to 338,000 SGD for a Grange - and this is without COE!
COE in singapore is apparently 91,000 for a car above 1600cc .. close to 350,000 SGD for a maloo!
Road taxes of: 7,332 SGD a year!!!
**edit - had a revelation: this must be why asians love rice so much ... evolution/survival theory: in order to avoid monstrous road taxes and COE payments, we have grown to like small capacity cars .. with lots of body kits, and mods - cos labour is cheap there.
time to write my psychology thesis on this lol :banana:
Edited by Jonno34
and you are right! this is my toy back home.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
