Hi guys,
As above, hoping someone has one as per the pic below.
Prefer one in good condition and with the airbag.
The other option is if someone has just the R34 GT-R Airbag and I can source a standard R34 Wheel (I think!).
Thanks.
Ewan.
took me ages to find one also, try hit up jesse streeter on his website and he can have one sent from japan, thats how i got mine, r34 manual steering wheel is the same as the gtr wheel so u can swap the airbags
Cheers Eli, thanks for your help! I'll pop him an email.
How much was it out of interests sake? I missed out on one the other day and it was $400. I'm hoping it will be around that sort of figure.
Ewan.
hey mate, i might have mine up for sale in a week or so, depends when my new wheel and boss kit arrive.
its in very good condition with only a couple of very small marks on it.
I paid $500 for it bout 2 years ago
Id probably be looking for around the $400 mark given its condition
  • 3 weeks later...
Did you end up sourcing one?
I have a reconditioned R34 steering wheel without the airbag - perfect condition with no marks.
Would be chasing $350 for it plus post.
Let me know if you are still interested.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
