Hi fellas,
Up for sale is my daily driver. It's lightly modified and im sure whoever buys it, will enjoy it like i have.
First owner in Australia
Mature aged driver and taken extra care of the vehicle.
If sold before end of May at this price, it will be professionally detailed inside and outside!
Runs like it's brand new. Mechanically A1
A really comfortable and smooth car to drive even with the Cusco coilovers.
A bargain at this price!
Feel the power of the 1JZ Engine and have to drive it to know how much potential it has.
Came from Japan with 76,000kms
Now has 115,xxx
Really low kms for a 1997 model vehicle
A full Major service completed including top tank radiator, oils, timing belt and more.Auto trans serviced.
Serviced every 5,000kms with premuim oils.
1JZ Engine VVTI 2.5lt turbo
Automatic
Pearl White
Air conditioner Digital climate control
Xenon headlights
Electrics
No RWC at this price. Won;t need anything either to pass.
Some extras include the following;
18 inch Work wheels
Cusco comp S coilover suspension (height adjustable)
High quality 3 inch dump pipe Japanese made through to mangaflow cat, 3 inch system.
Blitz SE Intercooler kit
Updated Series2 taillights
Oil catch can
Pioneer bluetooth, iphone,ipod adapter head unit.
Alpine amplifer
Alpine type S splits
Apline type S mids
Paint is still in excellent condition.
Interior is clean
Under body is straight.
A beautiful car to drive and choose this ahead of evo due to being extra comfy and smooth ride even with coilovers.
Located in Mulgrave, Victoria
Contact 0421249000 or PM
PRICE: $11,500
Thanks
post-35698-0-94523100-1336032153_thumb.jpg post-35698-0-35304400-1336032167_thumb.jpg
post-35698-0-40313400-1336032177_thumb.jpg post-35698-0-63513500-1336032185_thumb.jpg
Edited by HYPA13
https://www.sau.com.au/forums/topic/399267-1997-toyota-chaser-tourer-v/
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
