I thought yours was tuned local? Boost work, or speed lab.
Does toshi dyno tune or road tune the car?
Yeah... bit of both
Ive got a Toshi R33 ecu chip fitted to my standard stagea ecu (posted Toshi my ecu and he fitted the tuned chip)
Then its tuned at boostworx using a piggyback ecu, a AEM F/IC-8 which is a USA version of the greddy emanage ultimate, to adjust a variety of the settings such as injectors, etc
No reason that I can see that my setup wont reach 270rwkw now Ive got forged pistons, once I crank the boost; S15 injectors probably the limiting factor at this stage
Ive got a Z32 ecu sitting here, one day would like to have it rewired to suit the 3-row pin ecu plug of the stagea and nistune board fitted, then drop in some 550'cc injectors and go for 300rwkw...... one day.
Mail order tune dyno sheet.
This is std turbo at 12psi in WA
http://www.skylinesa...79#entry5379379
This is Hypergear R33 hiflow turbo at 15 psi in SA
http://www.skylinesa...54#entry5847954
They are damn good numbers for the psi. I was going to get a mail order tune about a year ago but never ended up getting any tune at all. Very good price for the results.
Actually PM sent, I need a new tune.
Edited by JiN_MaN
Curious after looking at some of those dyno sheets
1 )my r34 gtt exceeded 180kph in 4th gear and 1000rpm short of redline when the cat became a issue
Still making within 1 lb of boost as 3,000 rpm I know the diff lsd isnt stock but the gearset looked normal?
Is that normal ? On dyno dynamics dyno in 4th ? Should be 1.1 ??
2) the torque on a base flash no tweeks was a lot higher then a lot of big boost cars ? i know the series 2 gtt has different cams
And a few other tweeks and mine has a different camset from japan , they have a bunch of markings that i cant read
And it was in normal mode for tuning not shootout mode or anything odd
3) i dont run the z32 or updated pump , reg or injectors ( unless it came from japan tweaked ?) i have found other interesting items
That it didnt have listed on sales sheet ? Just seems odd to make so much power and torque on a near stock car on low boost on 98 octane , it never struggled till the ceramic hiflow hand me down cat issues
Afr was solid, duty cycle never pushed on injectors , smooth curve of power
And he was still pulling when the kph was getting up a fair bit
I video 'd the run and it just keeps going , like a rotor with light flywheel ?
Mine has a superlight flywheel so looks smoothe on the dyno and winds up without jumping around a lot
it was a virgin run on the dyno with it maybe its a fluke ?
Going to get a new cat and some other minor things before dumping lots of money
On a tune , the car has to be streetable and dependable , not a time bomb engine tune
All i know is the mines ecu drove horrible, the factory ecu drove ok but was a fail at 60kph torque was non existent with lightflywheel
Nistune and 2lb boost increase made the car so much better to drive in town fuel economy and coldstart / hotstart was better
It was worth the cost to update it And recommend it over boosting a motor thru the roof for power
Now i wish it was gtr to get the power to the pavement lol
Good to see i can provide comedy lol
im not a dyno tuner back when i built race cars and engine dynos were something f1 teams used
Even engine dynos were few and far between and expensive
im from the old school hand port and polish
Days and dual webbers you have to screw with daily at high altitude
Down the road from pikes peak ( hillclimb)
No i only had to rebuild piston engines
Until i woke up and bought a rotor to race
Pushrods make good drink straws lol they bend just right
Ask any ford /gm owner
i just realized im prob the oldest poster (child)in SA ? Think shane beats me just
But doesnt post
With the standard car;
They probably didn't rev the car out since the power had dropped off.
Where does it show the torque for the car? As far as I can see there is power boost and AFR but no torque.
Gotta dig the print out from a box in shed
But torque was listed as 503nm At about 3400 i think ?
The power never dropped off it was still climbing at 6400 rpm redline is set at 7400 In current state of tune? and boost rock solid only 1lb down from 3k rpm
The only thing that stopped it was the cat burning smell so he stopped it there ? After inspecting it the matrix was failing ( old xforce 3 inch)
And glowing red so it would make more power still ! (his gtt makes over 320kw automatic box ? but has z32 and greddy intake injectors pump and a slightly bigger turbo )
The afr reading was flat and no black smoke or backfires after o2 replaced and set on nistune
The first run about killed me from being so rich , weird cause the o2 wasnt a issue with factory ecu ?
I know it wont hit 320 at this state of tune but he reckons 230ish depending on what the deal is on the cams
And pulleys
I found the speed was way faster then posted results on links in every case ? Any idea why it was so high in 4th ? i wouldnt think the rear end gears are swapped out ? But it does have a nismo lsd from japan on import ?
Speedo is right on the money and his dyno recorded it the same ?
put it this way i had to ask what the dyno speed is limited too !!
Of course you cant hear anything in the dyno cell doors closed on a 35c day
And cant check the speed That high except on the track ??
so i was wondering about the dyno parameters if that could be why ?
It had the wheelbase programmed automatic via software ? i watched that part as it moved to match the car?
and bonnet closed as well ? The dyno days ive been too with sau use bonnet up
Stock ecu it ran a 172kw @redline -343nm But afr was all over the road
Anyway prob run it again in a few months if i can get the other bits done
just left me puzzled a bit
So you weren't talking about the linked graphs then?
If your putting the car on the dyno just to get a power figure then operators generally don't rev the engine out once the car has passed peak power, there is no point. If you are tuning then there may be a need to rev it passed the peak power point as they are still logging cells and adjusting the tune.
If the dyno operator doesn't enter the final drive ratio then the torque reading won't be accurate. It doesn't effect the power reading only the torque.
Also ramp rates have a big effect on both power an torque outputs. AFAIK that is the point behind the shootout modes to give a fixed ramp rate to compare results, but even then they aren't really comparable as strapping can also have a large effect on outputs.
Edited by D_Stirls
Nistune board is $242 plus install $60 total $302.
Z32 ecu need modified for R33 cost $60-80.
Z32 ECU $100-200.
So just ecu $462-582.
How much is dyno tune?
Is SA very cheap?
In Sydney around $150 /hour.(around 3-4 hours)
a mate paid 200 bucks for a z32 ecu, 250 for the nistune chip to be installed in the ecu, then 350 for a dyno tune.
so all up was about 700 bucks
    • Done about 5k Km on the PS5's now, excellent street tyres, great in the dry, and the wet, seem to be wearing very well, I haven't measured tread depth, but it looks like minimal wear, I also had a different alignment done about 1500km ago,  From looking at the tread wear, which is really only minimal, the alignment changes were based off how the tread looked, and how it felt throwing it around, the changes have shown great results 215/45 17 at 32 psi Front Caster: 5.5° Camber: -1.5° Toe: 0.0mm Rear Camber: -1.0° Total Toe-in: 1.5mm I actually prefer PS5's now over the RS4's, as the PS5's are much better in the wet IMO, and as the MX5 gets driven in all weather conditions doing daily duties, hwy trips, and blasts in the mountains, wet weather grip is high on my priority list
    • To update this thread. I got sent a replacement Attesa pro unit and all is now working as expected. Cheers
    • FD is so sexy she can pull off tri-spokes
    • Indeed they do. Best my diff builder could tell is it's a combination of the different cut/angle and it would seem they lap them in well on accell but less so on decel. He had to use a slightly different pattern to the lap to get the best result noise wise. Also as the rear diff runs in, the whine is getting less.        Overall they seem like a good thing so far. He's done a few neat crown/pinion before but all for race cars with loud everything, in most cases the exhaust is louder, so I am the first to notice.... and be somewhat of a pain
    • What do you mean by "test"? It sounds like you're just switching things on and off that you already know don't work. Get the wiring diagram and a multimeter and start looking for power where there is supposed to be power and earth where there is supposed to be earth. Look for continuity across switches that are otherwise unresponsive, etc etc.
