have a 1992 r32 gtr wanting quick sale has had gearbox rebuilt have all reciepts, respray, just had 100K service new water pump, thermostat, timing, all belts, hoses. Drives really nice has 19's, coil overs, 3 inch exhaust.
hasnt been boosted everything is pretty stock.
call nick - 0421883199
Edited by lilley's gtr
https://www.sau.com.au/forums/topic/399310-32-gtr-16000-brisbane/
  • 3 weeks later...
