Hey mate,
I got a R33 GTS-T in Sydney and wouldnt mind selling it. Its a series on 1995. I've had it for nearly 6 months now. I got it as a graduation gift from my parents but I'm currently doing postgrad and the car isnt getting much use, its just parked at the University. I was hoping for at least 10 grand for it but I woudnt mind giving it away for 9. If you want to discuss it more, my number is 0458 028 132.
Rusty
10 - 9 is a bit much for a series one sorry, but I guess it depends on condition.
Im looking for a mate so ill give your number to him and see what he thinks, cheers.
  • 1 month later...
Hey mate, I have a series 2 r33 manual for sale in custom purple. Chasing 8k ono, located in Sydney. I have posted a thread in for sale with pictures etc, and if you need any other info or are interested please contact me via pm.
Regards,
Steph.
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
