Hey guys, sorry if this have been covered for so many time. i just wanna know what width and offset i should get if i want the wheels to slightly stick out of my guards, like the 350z in the photo. Cheers!
PS. I am thinking of getting 18X9.5 all around with 263/35 tyres and i don't want to use spacers to fit the wheels on my car.
18x9.5+20 will stick out nicely
They're not 265's though surely!
You are going to struggle to put a 265/35R18 on the front of a RWD GTS-T I would have thought :wacko:
18x9.5's all around will go no dramas but I am an advocate of 225/40R18 all round or 225/40 255/35 staggered set-up.
I have 18x9.5 +22's with 265/35's all round on my r33 gtst.
Need a guard roll and modify the splash guards up front.
Actually got 7mm spacers on the back aswell, just clear.
Shit pic but yeah:
So do you mean that i need 7mm spacers on the back to clear the breaks? Plus, will your ride height be legal in SA? Cheers!
Sorry for asking so many questions! :(
Don't need spacers, just put them on because i had the space to push them out a bit further. In other words i could have gone +15 offset on the rear.
Unless the wheels have ALOT of dish, they should clear the brakes no dramas in a +22 offset.
My ride height is around 100mm give or take at the exhaust under the car
whats the camber set up. surely around the -3 for that. My 9 +22 with -.2 camber is about 5mm out the guards. however when camber was at -1.5 i was able to slide a 8mm to make it almost sit the same
Shit pic but yeah:
Are those TE37's?
The red spoke makes me think so :worship:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
