Duel Fuel Setup For Economy And Power, Anyone Else Thought Of Doing This?
......everything has to flow through the rail back to the tank unless you're running some sort of dead head system......
Precicely.
  • Replies 44
Posted Images
ok manifold vacumn would make sense... :)
So is this 3/8 solenoid is on each end of the rail (inlet/outlet), or just on the return with twin entry rail still?
yeah Im still not convinced fuel sharing a common rail at WOT is a good idea, i know fuel travels pretty damn fast under the pressure its at, so as these solenoids switch, one fuel will push the other out very quickly. But in saying that, I imagine you could gain a few thousand revs at least, in the time this took to happen..Even a momentry hiccup could be detrimental..really you would want some sort of octane sensor in the rail to be safe..
However a twin rail system each with its own dedicated tank/lines that switches to secondary injectors and maps at desired point I think would be much safer.
Although it is somewhat more complex in design it would be much simpler in setup and usage..
I'm thinking I would just have the secondary tank setup with an arming switch as well so it wasnt always primed on start, gives you a safety net for rainy days etc...or if the tank runs empty before your primary tank.
I'm actually quite warming to this^^^ idea .. though with 2 e85 outlets within a km of my house I know which path I'll be taking ;)
Just set it up like a rotor primary and secondary rails but drop the primary out during transition... easy.
Two tanks and lines etc
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
