Am new to this so not 100% how to make this add but am selling my car due to two main reasons
1. Want to downgrade to something cheaper so i can mess around with mod and learn more about modifying still very new at this T.T
2. Uni school fee is killing me ><
Nissan Skyline R34 2000 model GTT
all import/ transaction history are available if needed and also am happy to do any test just contact me we can work something out :D
car sitting on 197ish kwrw all the mod was done at "oh performance"
detail and pic can be found at "http://www.carsales....find=r34|CarAll"
done 81xxx km
$18,500 ono or am open for swap
contact [An] 0401 844 889
https://www.sau.com.au/forums/topic/399458-2000-model-r43-gtt-need-new-home-d/
last bump and last prices drop if doesn't get sold by end of July plain to keep the car ......so if anyone want a cheap clean reliable r34 gtt come get it now $17500 cant go any lower need to pay my uni loan ><
