hey michael , how are ya man , are you just after some stock rims with stock tyres on them or you want some full slicks that can fit 16" rims i can sell you as well man ?
let me know if your interested
regards anthony
https://www.sau.com.au/forums/topic/399482-pair-of-rims/#findComment-6345487
Hey anthony
Kinda after both lookin for a pair of stockies wit tyres for the drags cause I dnt wanna fry the 19s
An I'm after a pair of full slicks for my old man aswell for his 15s 28" tall
Can u pm me a price cheers
https://www.sau.com.au/forums/topic/399482-pair-of-rims/#findComment-6345520
