is there any efficiency gains from doing this?
most aftermarket kits are mounted vertically, but i noticed on some cars, such as gtr's, that the factory has mounted them on a slight angle?
is this so that the air passing though has to work harder 'against' the surface area of the fins and tubes instead of easily flowing 'past' them?
any thoughts would be much appreciated!
Doubt it makes much (if any) tangible difference. Could simply be a looks thing as much as performance.
The GTR one on an angle though - at least with a S3 front lip - the bottom of the cooler sits even with the bar. If it was vertical there would be quite a gap up the top of the cooler so it could be about reducing the gaps between bars/cores etc.
From a thermodynamics point of view, the most effecient set-up would be perpendicular to the air flow (i.e. vertical) which would allow the maximum amount of frontal surface area to be exposed to the air flow. Slanted intercooler = less frontal surface area. More airflow = more stuff to cool the charge. This is the principle behind n1 vents and the shape of some bumps to direct air to the intercooler/radiator. It should be noted that manufactures design will play a part (i.e. were the internal channels designed with a slant install inmind toallow better airflow through the cooler).
But i also agree with Ash, any difference would be fairly intangible unless the intercolller was slanted at a large angle (say 15deg).
Actually if you look at the old school F1 car intercoolers they are mounted (As are radiators) at and angle to the air flow. It reduces drag for a given amount of heat exchange.
In a road car it is just for packaging.
....It reduces drag for a given amount of heat exchange.
Both true, but from a thermodynamic point of view; this is not the optimium set-up.
air to air Intercooler design will always be a balance between drag reduction, packaging and cooler effeciency.
Edited by wedge_r34gtr
Iv always mounted coolers on a slant in my eyes it will restrict airflow to a extent meaning more time to cool the fins and tubes or bars also when on a skyline with not much room allows more surface area to be open before the bar support
the position and geometry of the ducting feeding the heat exchanger really dictates it's position or angle of attack, as djr81 said, alot of grandprix cars are slanted on an angle to reduce drag in terms of frontal area exposed to the air stream and the ducting pod itself, there is nothing less efficient then just letting an intercooler or radiator "Swing in the wind" so to speak.
so to summarise I would say ducting makes or breaks the effectiveness of coolers.
Isn't it better to have air flowing quickly so there is more cold air hitting the fins. Slowing the air down means the air gets hotter so is less efficient.
This is how I see it anyway. Not saying I'm right. But I don't see any benefit from mounting it at an angle.
Im not 100% but it's always worked on the many Iv done way I look at it is it will create a slight pressure drop behind the cooler which would help the radiator as well because it will cause the air to aim more into the radiator centre
you want a high mass flow rate for more heat transfer
so therefore more air going through it
so therefore less time per particle
i can dig out my thermodynamics book if needed
You could have all the fancy ducting and frontal exposure in the world, but unless that heated air has some where to go (read: low pressure after heat exchange), it wont do much.. Too often you see people install these 100mm+ thick intercoolers just to have them sitting near-flush with radiator/fans/supports, etc.
It's much more worthwhile to examine the air that is trying to escape than worrying about how the air enters.. My two cents.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
