Im currently parting out my R34 GTT with GTR runing gear. everything must go.
R34 GTR parts as follow
Gatrag 6 speed gearbox, perfect working order, good meat left on 4wd transfer case. comes with pull type AND push type fork and slave cylinder, 5month old nismo gearbox mount, and support brace, complete with GTR shift knob, AND front prop shaft: $4000
R34 GTR Year 2000 V-spec turbo, perfect with no shaft play $350/pair
STD GTR injectors $200/for 6
Pearl White GTR aluminium bonnet, minnor dent on the front area, fine as is or just a touch up: $500, bargin!
R34 GTR Tail shaft: $200
Light weight flywheel (7kg) and exedy heavy duty single plate clutch: use less than 9 month with light foot, never launch, just bed in. paid $1600, pull type $800
Vspec dash cluster, 25xxx or 26xxxkm on the clock (Rare very low K), no clouds, no marks. Perfect!. $200
Apexi boost controller. with leads. $50
front subframe, $150
Uprights: $150 ea side
Lower and uppper arm: $120 ea side
Steering Rack, 2.5 lock to lock : $150
Sway bar: $50
Front Shaft $120 ea
Or the whole front suspension setup $900
Std R34 gtr intank Fuel Pump. higher flow than pervious model, support up to 280kw awkw no worries, $120
V-spec very little k's travel. $650
V-spec hydroic pump assembly, wiring hardness been modified, suit spare $200
STD rb26 AFM $100
GTR twin turbo 60mm into 70mm front pipe. mines style, very good flow probably the best twin front pipe design. $250
34 gtr fujisubo Full exhaust. Jasma Approved. flows very well and very quite, 80mm main pipe, made over 300kw with this pipe before. $350
CATCO 3" High Flow cat, Brought for $200, selling $80
OEM R34 GTR sideskirt with front guard lower skirt, RHS minior twisted $250
GTR replica full carbon fiber rear wing with OEM height (custom requested for oem height) $350
R32/33 GTR parts:
R32/33 Apexi Power FC, complete with hand controller. a minor scrach on the hand controller but wont affect the readding at all $750
GTR BOV $120/ pair or $70 each.
R32 intercooler $70
Thick full alloy radiator 8 months old, suit R32 $80
Item located doncaster east Melbourne.
PM call or text 0433289998.
cheers
joe
Edited by godsmind
some pics on this thread
http://www.skylinesa...66#entry6333066
Boost controller is actually solenoid only. no actual control unit. sorry for the miss leading.
V-spec R34 diff very little k's travel. $600
Will upload as much pics as i could.
Edited by godsmind
Right hand Upright: $150
Right Lower and uppper arm: $120
Sway bar: $50
Right Front Shaft $120
V-spec Diff very little k's travel. $650
STD rb26 AFM $100
R32 intercooler $70
  • 1 month later...
  • 4 weeks later...
Sway bar: $50
STD rb26 AFM $100
R32 intercooler $70
hey man do u still have the lower controller arm?
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
