1999 Model S15 Spec R - JDM
JET 515 Gunmetal Grey.. Quick and Clean
$16,000 firm
Going Overseas
1999 NISSAN SILVIA S15 JAP SPEC R
Up for sale is my S15, Never had any problems with the car. Fast and reliable, and been serviced it every 5000kms with good quality oils. Just had service done 02/05/12
It has done 164,000kms, but many of it are highway km's - Previous owner used to study in Sydney but moved to Gold Coast and drove up and down from alot.
Its a 1999 model Sper R Jap Import, with a factory fitted Aero Bodykit. Removed the rear GT spoiler for a cleaner look.
It's got many aftermarket mods, but they are all done tastefully and professionally.
ENGINE:
- 164,000kms on body
- SR20DET – Rebuilt with standard internals 10,000kms ago
- 6 Speed Manual
- Excedy heavy duty organic clutch with lightened flywheel
- New Turbo Gasket Kit just fitted
- 3" Turboback exhaust with X-Force 6” Cannon
- K & N podfilter with heatshield and CAI
- HKS Type S intercooler
- Walbro GSS342K Intank Pump
- Earls oil cooler, with filter re-locator and thermostat
- Nismo engine and gearbox mounts
EXTERIOR:
- Gunmetal Grey Factory Colour
- Aero Front Bar with Spec R side skirts and Rear pods
- Standard Jap Spec HID Headlights
- Rear Guards Professionally Rolled
- Night shade tinted tail lights
- 5% Tint All round
WHEELS/SUSPENSION:
- Standard S15 Wheels painted Black with Gloss Finish
- Blox Anodized Red Wheel Nuts
- Near New 205/55/16 Tyres on Front 80% Tread
- Near New 225/50/16 Tyres on Rear 80% Tread
- Tein Super Street height & damper adjustable coilovers
- Nismo swaybars front and rear
- Nismo front strutbar
- Tein tie rods & ends
- Tein extra lock spacers
- Polyutherane front control arm bushings
- Cusco adjustable castor arms
- Whiteline adjustable camber arms
- Cusco adjustable toe arms
- Polyutherane subframe bushes (not the inserts, the whole bush has been replaced)
- Standard Spec R strut brace in the boot
INTERIOR:
- Greedy Profec B Spec II Boost controller
- Apexi Full Auto turbo timer
- Shadow- Oil temp, Oil pressure, Water temp & Boost gauges
- Red Recaro SR4 seats with bride rails
- Trust/Grex gearknob and shiftboot
- 7” Pioneer Double Din Touchscreen 6 stacker DVD player
- Alpine Type R splits up front
- Alpine Type R speakers in the back
- Sony Xplod subwoofer
- 2 amps - 1 for speakers and 1 for sub.
- The sub is in a fiberglass enclosure, and the amps are held in place by custom brackets
- Audio system is neat and tidy, and everything - including the sub box - is bolted to the car properly, and doesnt move around
- Ice Cold Air Con
- Viper Alarm with Immbolisor and central locking
- RWC will be supplied upon sale after deposit is put down
- Fresh 6 months Rego till 09th October 2012
- Might come with plates JET 515 depending on sale price
- Located on Brisbane Northside
- Call anytime 04388 60 307
$16,0000 firm.... NEEDS TO SELL THIS WEEK
https://www.sau.com.au/forums/topic/399545-1999-nissan-silvia-s15-spec-r/
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
