I have the following parts for sale:
  • RB20 Manual Gear Box: Used condition, smooth through the gears. 1st to 2nd can be sticky when cold: $400
  • Genuine R32 GTR front mount intercooler: Very good condition: $200
  • R32 GTS KYB rear struts: Un-used, still in box: $100
  • Full set of R32 GTR struts and springs: Genuine GTR struts and aftermarket springs: $150
  • RB30 Manual ECU: Working Condition: $35
  • Volk GR-C rims: Good condition, comes with 40% tread, missing one cap (PCD 4x100, 7.5 inch wide),
    Comes with adapter spacers to suit PCD 4x114.3: $450
  • R32 GTS/GTR Steering Column Surround: Good Condition: $30
  • Genuine Nissan Wheel Chocks x2: Used Condition: $15
  • HR31 Auto Gear Box cross member, suit RB25 Gearbox conversion: Good Condtion: $40
  • R31 Clutch master and slave including lines: Used Condtion: $70
  • RB30 AFM: Unknown working Condition: $20
  • R33 / RB25 Power Steering Pump: Unknown Condition: $30
  • HR31 Coupe Boot Lid: Good Condition, Black: $75
  • Nissan Space Saver Wheel: PCD 4x114.3, 100% Tread: MAKE AN OFFER
Postage at buyers expense.
Postage or Pick up for gear box, intercooler and wheels will need to be organised by the buyer!
See Attached Photo's.
When they come off the car they were in working order. They arent sqeaking and they arent leaking.
Shipping can be organised to Melbourne at your cost. I will get a quote from pack and send tomorrow.
  • 3 weeks later...
Yo man can i grab the r31 clutch master cylinder & slave off you?
I live in nsw so youd have to post it. Ill cover the charges for that obviously! =)
Msg me! 0402935005!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
