R34 Gtt Parts/trims And Random Parts
R34 Coupe Rear seats $50
R34 rear quarter plastic trims $75
R34 front guards (white will not separate) $250
R34 Interior carpet (has wholes due to roll cage in the back) $30
R34 Rear parcel shelf $40
R34 Boot Carpet (includes boot floor and sides) $75
Stock arms (castor rods, tie rods, camber arms) $40 Each
R32 gtr standard coilpacks $50
R34 Gtt Bonnet Hinges $20
R34 Gtr-Gtt Bonnet Latch $40
R34 Spare Tyre $30
R34 Passenger Kick panel with flare and bracket $70
R34 Rear Seat Belts $60
R34 Std Cat Converter $15
R34 std gauges $50
Front Seat Belts $100
Roof Lights (front and centre painted black) $50
Thought I’d start a new thread coz the other one is all over the place
Please sms me on 0432647023 for pics
All located in Mordialloc 3195
Cheers
Herb
  • Replies 69
Hey Herb, Have the speaker grills got nasty holes in them are are they untouched? If they are untouched any chance of separating them from the actual parcel thing for postage purposes? PM if you can please... Cheers Mat!
No headlights mate
Na unfortunately the speaker grills have these child restraint mount holes in them..
Cheers
Damn :\ I thought i might snag one sooner or later, the only ones i ever found listed as R34 turned out to be R33 when they turned up.... Thanks for the reply!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
