R34 Gtt Parts/trims And Random Parts
  • Replies 69
UPDATED LIST:
R34 Coupe Rear seats $50
R34 Front passenger guard $140
R34 rear quarter plastic trims $50
R34 Rear parcel shelf $40
Stock arms (castor rods, tie rods, camber arms) $35 Each
R32 gtr standard coilpacks $50
R34 Gtt Bonnet Hinges $20
R34 Passenger Kick panel with flare and bracket $50
R34 Rear Seat Belts $60
R34 std gauges $50
Roof Lights (front and centre painted black) $50
R34 GTR gear surround with leather boot, ash tray and double din surround $200
R34 gtt snorkel for the airbox $50
Standard front bar indicators $40
Standard guard indicators $40
Standard clutch with a fair bit of meat on it $50
interior cards b pillar and c pillar $70
Door cards $120 each OR $200 pair
Glove box $40
Passenger airbag $80
Airbag Ecu $80
Climate control unit $100
Vents with the fancy shinny centre guides $100
Panel under the steering wheel with the coin tray. coin tray has been modified to fit my defi control unit so theres a whole in the back of it but is still in perfect working condition $50
BEST CONTACT: 0432 647 023
Located in Mordialloc
Most parts will be chucked out in the hard rubbish collection
Cheers
Herb
Edited by GTXR34
All PMs replied
GTR Gearsurround SOLD
Kick Panel and flare Maybe sold, gotta figure out how to get it up to QLD. Auspost wont do it..
Also have the double din conversion for GTR's and GTT's for sale now..
- Climate control
- The metal bracket that holds the climate control and head unit
all thats needed is the double din surround which i have pictured above but already sold
PRICE: $200
Please PM or SMS on 0432647023
Cheers
Herb
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
