All parts are from a series 2 97 r33 gts manual. Had a impact in the front but fixable with a dressed front cut. It is fixable but I have decided to strip it. Just ask if you need something not listed. I will post most items. If its bigger I may get you to source your own courier. I can find at least one day a week I can meet a courier.
Also if you need something and the price is honestly a bit steep don't be afraid to have a chat to me about it. That doesn't mean I want to be low balled on everything but id like to think im fair and reasonable. If you disagree however please don't comment on that lol. If you would like pics please let me know. Il try and get pics tonight of the non standard gear.
Manual Conversion
Series 2 sunroof shell. Currently rolling with manual conversion installed. 3k Can be negotiated as to how much i remove or keep there. on repariable write off register
Full series 2 interior
Front seats
rear seats
COMPUTER $100
TAIL SHAFT $200
R200 WITH CRADLE DIFF IN VGC $250 ABS diff
Abs pump
DRIVESHAFTS $65 EACH
HICAS $80
POWER STEERING RACK $150
POWER STEERING BOTTLE $20
BRAKE MASTER CYLINDER $150
SWAY BARS $20 EACH
Horn $20
Front wiper motor - $50
Rear Wiper Motor - $50
STEERING COLUMN $50
(Body parts)
series 2 headligtht Passenger side 175
Passenger front guard $50 very slight mark
Drivers door 300
Pass door $300 includes glass window reg and everything
Boot very minor damage to rear drivers side lip. $60 no wing
Rear tail lights
(DASH PARTS)
turbo cluster with 167000km's $150
DASH NO CRACKS OR BUBLES OR HOLESLOOKS LIKE NEW with airbag $300
ALL VENTS $75
GLOVE BOX $30
CENTRE CONSOLE $150
CLIMATE CONTROL UNIT $75 BOTH BUTTONS WORK
HEATER CORE $70 A
IRCON CORE $70
HEATER FAN $20
(INTERIOR)
INDICATOR / WIPER SWICH Headlight, fog lights / ASSEMBLY $100
HANDBRAKE $30
REAR TRIMS $30 EACH
SEAT BELTS SET $150
INTERIOR LIGHT $15
PLUSH CARPET $70
PASSENGER DOOR TRIM $75
POWER WINDOW SWITCH PASS SIDE $25
BOOT TRIMS $70
POWER ANTENNA $50
PILLER TRIMS $20 EA
ROOF LINING $40
KICK PANELS $10 EACH
R33 GTST. Skuff plates, both sides $35
Rear Seats - $100
Door seals $25 each
Boot seal $25
Rear ¼ trims - $50 each
Rear1/4 window surrounds $50 each
A pillar Trims $20 each
B pillar trims
Door cards
Rear Vision Mirror $20
(ODDS AND ENDS)
FUEL TANK $30
FUEL PUMP $50
WASHER BOTTLE $20
RADIATOR OVERFLOW BOTTLE $20
WINDSCREEN $200
QUARTER GLASS $30
REAR WINDOW $200
BATTERY HOLDER $20
WIPERS $15
FUEL LINES $50
FUEL FLAP $10
FUEL CAP $10
Engine Mounts - $80
Radiator overflow bottle - $20
Stock BOV - $40
Sun visors $30
Handbrake assembly & cables - $160
Sing out if you need anything not listed. PM me or get me on 0424506009
  • Replies 62
Hum. no idea what your building there. there would be a few more variables like what type of car its going in for the leingth. iv never tried ether so im not sure sorry mate.
i honestly cant answer that having never done it before. could you possibly ring a local wrecker or import car workshop? or maybe have a search around here? id hate to give you the wrong info. Im also not splitting teh tailshaft from teh manual conversion yet.
Sure do.
i also have an aftermarket wing thats slightly bigger than the series 2 wing. looks really cool. il get some pics of it. Also have a front strut bar. Heaps of other stock bits i havent actually listed. Will try and list them individually but sing out if u need anything.
Have you got the driver side plastic bit for the electronic windows ? Also the plastic bit that fits around the inside of the driver side door where the open handle is.
Where are you located?
Edited by DarkRyda
Hey mate. Im on the Gold Coast. the plastic holder for the window switch is cracked at the base around where the door handle cup is. You probably dotn want it then?
il have a look for the handle bit you want later when i get home.
hi mate,
i am after driver side window door rubber seal which runs along the door.its like thick rubber...someone tried to pinch my car so they cut the rubber to unlock the door from the top.
thanks
Hey mate, chasing 950 for the whole manual conversion. it is a na box but im told they are still good for a mildly modded turbo car if thats what you have.
Others iv sent pm's to. Thanks!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
