I did not know the S300P was available? Did he elaborate on the wheel/housing sizing on this?
He said it could be made by custom order... Rear housing was a 0.80 T4 divided, wheels I'm not 100% sure but I believe they are similar to the EFR8374 as he mentioned once it was a prototype for that turbo
Now the choice is to get a surge ported from cover or not and where to buy it from...
Surge cover for sure. They are a winner on those turbos. I think the CEA design wheel works well with it.
I will PM you a quote I received for a friend!
  • 6 months later...
This one will be a rear wheel drive GTT with an RB26 in it.
I'm looking for a single turbo/manifold combo that will net around 370kws.
Motor will be kept pretty simple with a built bottom end, drop in poncams, very little headwork, running on E85.
Looking for 20psi by say 4000rpm.
If I were building exactly the same thing, going by the things I've seen out and about these days - I'd go for a single entry FP GT3076R HTA with .82a/r hot side on a 6boost manifold.
I'd say your 370kw on E85, and 20psi by 4000rpm should be pretty achieveable with that combination - potentially with change.
I was trolling around and found this thread - until seeing this I couldn't specifically remember when I had recommended the HTA3076 as I normally have that kind of convo in PM and I'd never found it.... this would be why I didn't remember it, you had asked about a setup for an RB26 :D
Fast forward a year, the project turned into an R33 GTS25t with an RB25 in it but the same power/spool target and you took the plunge on the HTA3076 - looking forward to final results, but do you know if it hit the 20psi by 4000rpm rpm target yet?
Haha i just read this thread again this morning after searching around in circles :P I think the target was met or close too it.
I was pretty confident that the RB26 would do it, and suspect the RB25 should be good for it too - though certainly will be interesting to know how it all comes out. It'll probably never happen to mine now (it was semi-on the cards when this thread started - hence the quick response), so would be good to enjoy vicariously!
I think the final tune was to be last week or this week so it should be close too result time! Im keen to see the final numbers too :yes:
Final tune will be late next week now as car is at the painters. Tuner was too busy last week so I took the opportunity to send it to paint in the meantime....
Patience guys, results soon... :yes:
Late next week is good news to me, I had assumed it was going to be a while before you got back to it :D Would be awesome to see what the overall finished product comes out like when its done :)
Are you kidding me? :P I am going to fall off my seat with anticipation heheheehe
Really keen to hear, good luck mate :thumbsup:
  • 4 weeks later...
I've managed to last around 3 weeks without annoying you :D How are things going with this, did it make it to the tuner - or are there still plans to get it back on the dyno sometime soon?
It's on the dyno now actually. Been on a few times this week. Having issues with the ecu losing/not storing tune. Thinks it's fckd. Similar issue to when run in tune was being done.
Damn :( Was really hoping it would go well for you as i was super keen to see the result ;)
Hope the ECU issue gets sorted out and you get the results you are after mate!
Haltech Platinum Pro.
ECU is off to Haltech tomorrow to get checked out.
One day............
Who you speaking too at Haltech?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
