Fingers crossed mate! Hasnt been the smoothest start BUT at least you know you have killer performance to look forward too! A nice eye opener for some ;)
The ECU was in the car when I bought it, could've been to the bottom of the ocean for all I know...
Oh dammit, I had assumed it was a mostly fresh build. Back to my initial sentiment, I hope it isn't a major - this is probably my favourite GTS25t build I've caught wind of and is going to be a potent race car when it's sorted, so close!
Thanks Lith, it's my favourite GTST build too! :yes:
Gotta say, I actually prefer the look of it to my 32 when side by side in my shed. It's really starting to appeal to me.
I think my son my have his hands full getting it off me once done!
I actually drove it last weekend at SMSP South in a club day. Still on run in tune and oldish tyres. Enjoyed it, handled well, made it through the whole day without any issues, all good!
Managed a 1:03 which given the power, tyres and the fact I'd never driven the South Circuit before was not too shabby. Reckon it'll be fairly quick once finished.
Thanks again for your help.
That is awesome! So the run in tune was still the 390hp or whatever it was? I assume it feels fairly responsive as per the dyno print out? :D
I really want to try the South circuit, looks like fun!
VCT was off, another part of the glitch. Not really responsive to be honest, needs more powah!!!
I wasn't revving it particularly hard though, nothing over 6000rpm, that wouldn't have helped.
I hated the South Circuit after the first run but kind of warmed to it's little challenges throughout the day. Would go back.
A bit surprised it doesn't seem that responsive, though 6000rpm and no VCT will be keeping it from sharing its best - as you indicate. Hopefully with more rpm, more boost, and it's proper cam timing in effect it will become a different beast :)
And awesome to hear it has had a bit of an outing, well promising!
Well I now know why it felt sluggish last week. It had a hole in the silicon joiner off the turbo. Was only making 225kw.
I drove it again last week on 16psi/280kw and managed a few 1:44s around EC full circuit. Looking forward to a high boost run when it stops blowing up silicon. Managed to destroy 3 hoses in 3 sessions.
That's frustrating, but good to know its not an indicator of the turbo's performance. How was it's response without the leaks? Granted at 280kw it still won't be showing its full magic - but its got to have been a bit better!
Thanks for the updates, looking forward to hearing how it goes with the wick wound up a bit - those sound like really sharp times already! What times does the GTR do there?
That would explain a few things... I'll keep the silicon joiner thing in mind now :O
That is a damn quick time for EC mate! Wow!
what about the T04z?
They make that power and then some all day, infact it's what Denzo has on his drift s15/RB30 so its good for response
It's an RB30..... Different story!
The numbers and response this turbo is producing will be impressive... If not the HTA3582 would still be considered responsive and make more power again...
If you see the times already done as per the post about you will realise this is one fast and well setup car! That sort of time on low power is a good indication of things to come! :woot:
  • 3 weeks later...
Guys,
About to build another track car and want to go down a different route to my current R32.
This one will be a rear wheel drive GTT
I'm looking for a single turbo/manifold combo that will net around 370kws.
Motor will be kept pretty simple with a built bottom end, drop in poncams, very little headwork, running on E85.
Looking for 20psi by say 4000rpm.
Give me your thoughts please.
If I were building exactly the same thing, going by the things I've seen out and about these days - I'd go for a single entry FP GT3076R HTA with .82a/r hot side on a 6boost manifold.
I'd say your 370kw on E85, and 20psi by 4000rpm should be pretty achieveable with that combination - potentially with change.
I'd like to take this opportunity to say BOOM! headshot. Can confirm the above setup is capable of 20psi by 3700rpm and 391rwkw, so plenty of change - courtesy of R34GeeTeeTee doing everything mentioned bar the built bottom end, and E70 instead of E85. I like being right, especially when I would look like a right douche if I wasn't :D
See the attached dyno plot - has his 360kw GT3076R result to compare with the new HTA result, the old faithful GT3076R has no answer for the HTA anywhere.
  • Like 1
thats awesome!
148000kms = original?
100% original including the headgasket mate! Car ran 200kw for a while up too 115000km, 250kw up to 150000km and then 360kw to where it is now... The 391kw starts at 148000km with its first actual drive tomorrow...
During the turbo swap we kept this quiet and say back to see what people had to say, it is now proven twice that these turbos are more than capable and as Lith said the old GT3037 had nothing on the new HTA76... That 3037 was maxed 100% too...
  • Like 1
It certainly was a good call lithium, wish id of gone TS HTA now, but im still happy,
looking at the printout, the HTA is running more boost than the GT3076 so is this because the GT3076 is out of efficiency and cant run that same boost?
We tried more boost in the 3037 bit it had nothing left to give...
how would the HTA 3076 compare to the HTA GT3582R that lithium was advising in another thread
If I were to extrapolate from what I have seen elsewhere I would say prepare to see around around 400rpm more lag and maybe up around 460-470rwkw on E85 with the right setup and the end result shouldn't be too surprising.
  • Like 1
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
