Up for sale are 2 sets of Cannards, original Auto Select (Brand new, only just opened) never fitted, Genuine Auto Select items. $550
Box components
Cannards
Mines Cannards - 2nd hand, still in immaculate condition. $250
2nd Hand Cannards
  • 3 weeks later...
