Hi guys, have a 200sx Silvia S14 for sale. 2000 Series 2.
Details:
Mileage at 137,000 kms
Rego til Jan 2013
Mods:
Brand new vertex full bodykit
Walbro 255lph fuel pump
Garrett t28 turbo
Greddy intercooler
Greddy BOV
cannon stainless turbo back exhaust 3 inc"
Greddy front mount intercooler.
S15 spec r f/r suspension with lower king spring
Custom stainless steel and silicon
Custom make bracket to hold intake
Custom back light
K&N filter
Defi gauges(water/oil pressure/boost/)with shift light
Extreme heavy duty clutch with lightweight flywheel
Abs brake (with abs airbag)
Full ecu tune (nistune)
8k/6k HID/high beam/low beam
Apexi Turbo timer
18 inch nismo(cp) wheels (front/rear)
Zum 18x8.5 30 5/114 front wheel sz
Zum 18x9.5 35 5/114 real wheel sz
Comes with B&m Short shifter(not install yet.)
Tyres:
255/35R 18 94Y XL KU31 SPT KUMH
225/40R 18 92Y XL KU39 KUMH
(Changed 5500km ago)
ACE alignment FR&rear pass.
Only Motul engine oil used, with filter(serviced every 3000km~5000km)
Gearbox and diff oil castrol
Using NGK spark plug (serviced every 3000km~5000km)
500watt sub and amp.
Inside under neon (as you can see in pic)
Clean inside & outside.
serviced by chasers motorworks
Perfect Compression (recently tested.)
This car has had a lot of work/money put into it.
serviced regularly with top of the line product.
Not a cent has been spared.
No accident history
Car runs perfectly fine despite its age and mileage. A/C works well for both cool and heat.
Selling because due to upgrading.
I also have stock BOV and intake piping
contact me if you want more details or pics
Price: $11,000 negotiable
Contact: 0449979697
post-93877-0-89066300-1336468278_thumb.jpgpost-93877-0-48386900-1336468283_thumb.jpgpost-93877-0-01397700-1336468288_thumb.jpgpost-93877-0-62002100-1336468294_thumb.jpgpost-93877-0-69802800-1336468301_thumb.jpgpost-93877-0-95889900-1336468308_thumb.jpgpost-93877-0-59255500-1336468315_thumb.jpgpost-93877-0-99978300-1336468322_thumb.jpgpost-93877-0-70533400-1336468330_thumb.jpgpost-93877-0-79008200-1336468338_thumb.jpg
https://www.sau.com.au/forums/topic/399646-vic-00-200sx-s14-s2-for-sale/
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
