Hey Peeps,
Ok so I bought some after market led parking lights to get rid of the old yucky yellow ones but i can't find were they clip into i have tried looking but all it feel's like is that I'm about to brake some sort of loom.
I can get to my actual lights fine but the parkers seem to be a whole lot harder.
Need some fresh idea's or advise cheers.
The parkers are separate, they are in fact a lot easier to do than the main headlights. You should be able to see a small grey plug towards the outside of the headlight assembly, I've attached a picture indicating the parker. Just twist it to the left and it should slide right out.
Yes you basically have to reach right into the corner - you'll feel the little plug sticking out. Simply turn it counter clockwise a bit and it'll pop out. Installation is exactly the reverse. Those with big hands may struggle with it.
  • 1 year later...
Hi guys, just digging up an old thread real quick...
Can anyone confirm if removing the parker bulb is the same process for an R34 with factory Xenon headlights? I'm having a few issues myself getting them out!
Cheers! and Merry Christmas :cheers:
Still only halfway through haha, will need to unbolt the bottle on the passenger side and maybe even take off the pod, but otherwise seems pretty straight forward! The drivers side LED went in perfectly btw, thank you!
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
