Just wondering what other tools are supposed to occupy those spaces in the boot compartment?
These are my Nissan tools but there are other spaces next to the pliers - and for what?
I think what's supplied might vary from car to car, but am I missing something?
https://www.sau.com.au/forums/topic/399709-nissan-boot-tool-set/
I will have a look in my boot when I get the car back from the painters, I have a little bag of tools, and there not all in the styrofoam... Will check to see which ones I have and if there genuine etc... Interesting!
Hey had a look in my boot today to find some tools...
my thoughts..
on the passenger side part everything is the same as yours terry.
then moving from left to right the section where i have two screw drivers, the red one i believe is non genuine, the black one i believe is, it says japan on there but not nissan, strangely the screw driver is both a phillps and flat head as you can pull the whole shaft out and use either end?... so im not really sure if something bigger is meant to go in that spot, and if the black one is genuine, why are there two spots? only one would be required for screw drivers, unless something else goes there?..
the next section i believe should be full of spanners, and i seem to only have 3 of the five??... the clippers im not sure where they are from, they just came in the blue bag next to it which i dont believe is genuine either...
pretty interesting stuff, thoughts?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
