We have Kakimoto, Blitz, HKS and JJR Exhaust Systems in stock for R33 GTR and ready for immediate delivery.
See our website for details and don't hesitate to pm me if you have any questions:
http://justjap.com/store/home.php?cat=273
Cheers,
Steve
