Hey guys,
Was changing my oil this arvo and noticed that my front driverside front driveshaft boot is in a word GONE. What would i need to fix this issue. You'll understand better when you see the pics.
http://img402.images...4/p5090010a.jpg
http://img401.images...12/p5090011.jpg
I'm in need of a passenger side inner boot if you find an aftermarket or oem part to fit. There are wraparound ones you can temporarily use if you get stuck.
That one is certainly the worst I have seen, did you find the boot?
Sorry to see that Josh,
I probably don't need to tell you, but get it seen to pronto. I was a tight ass and left the boots cracked and separated for a few thousand kms on a honda. Instead of costing me a few hundred, it cost me a lot more because the uni joints went. The click on turning/accelerating sound that you get from worn unis.
Yeah im not driving it till I get it fixed. Crap timing as I was bout to drive it to cairns on friday for a holiday now I have to take the missos corolla seca.
That's the same one as failed on mine. I used these aftermarket ones: http://www.ebay.com.au/itm/220865687512?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
You just need to specify the size you need at each end (~75mm & 27mm) & they'll send it to you within 1 or 2 days, at least it arrived that quick for me.
The boot was a couple of mm bigger than it could have been but the stainless ties held it OK (so I was told by the mech who put it in for me).
Hard to fit leon? Thats great news thanks for the link. Do you know what your measurement was by any chance?
I decided the same thing. Only bought the CV boot so I could get it done in my timeframe rather than waiting for the mechanic to order it in. The good thing about you being in Brisvegas is your specialist with most likely have one on the shelf
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
