ok due to the head fxxk of the A-LSD, I've decided to change to a mechanical LSD,
so do I just need the standard diff housing? can it be an R32 GTR one ( my car is R33 GTR ), is there any difference? also will the drive shafts and tail shaft bolt staight up to the standard diff?
Get one to suit a 33gtr and everything will bolt up. Go new though as usually you get everything you will need, instead of going 2nd hand and having stuff missing
but from what I have read, I need to change the whole diff housing as there is no after market diff centre to fit into the Active-LSD housing?
I just went through it all. :)
You need to change diff housing to a R33 GTR Non V-Spec. Not expensive, can get them for 200-300 2nd hand.
I thought you needed the non-spec shafts as they are different lengths when you measure.
But it turns out the actual shafts are the same length, it's the coupling big (forget the technical name, bit where the shaft connects with) that is slightly different and I believe it can be purchase separate if you cannot get shafts to suit
Makes it easier/faster if you can get the housing with the shafts together obviously.
The car with a Nismo 1.5 GT Pro is 10000% better than with the crappy A-LSD, which has no upgrade options.
It's set to the lowest lock setting and still locks incredibly hard when you want, very predictable. Any more I think would be too much.
My car now behaves like a RWD car in terms of hooking around @ a motorkhana with a bit of clutch or trailing throttle lock-up and turn - yet straighten the wheels and it 4 wheel power slides nicely or grips and goes depending on what you want.
Also induces some good mid corner oversteer where previously it would just understeer/plough off terribly doing the same things ;)
I didn't realise how bad the A-LSD was until changing over... I don't wanna sell the car now it's changed it that much
I don't know mate - I was told to get a R33 rear end specifically.
I know the part numbers for R32 & R33 are the same in terms of the Nismo differential... Doesn't mean the housings are though...
Someone will be able to confirm though 100%
I just did this in my gtst. I bought a second hand regular gtst diff and just threw it in.... everything fitted up fine for me, the only thing i needed was a new set of nuts and bolts to connect the halfshafts to the axles as the a-lsd halfshafts were threaded and the gtst ones were not....
Ripped out the pump and reservoir as well.
At the time I just shimmed the new diff, but thats shit and only lasted a few weeks and I absolutely locked the fark out of it.... next mod is either a kaaz or nismo centre.
Ye that doesn't surprise me.
Ideally yes you want diff & axles. It just makes it a simple bolt in/out (once you do the centre.)
But... if you can't get the shafts, you can use your v-spec ones as they are the same length. It's just the the coupling bit that's the different length betweeen VS and non-VS (the technical name for the part still escapes me)...
I can find out the proper name and shit next week exactly and report back. I doubt you'll find a R33 non-VS rear in a couple days. I was looking for a good 2 months for one priced appropriately.
spoke to a mate in the know last night and the R32 GTR diff and axles is a touch shorter...
so I'm after a R33 GTR non-Vspec diff and axles, anyone ??
Yes they are, I have measured them as I have a R32 GTR diff. from a 1994 car to replace my A-LSD. Just need some spacers machined, from memory it is only about 5mm.
OK I've got the Non V-spec diff and axles,
now I have a few questions about what to do regarding the hydraulics and electrics?
My thinking is, just block off the hydraulics from the pump under the car and rip everything from there to the diff out.. I'm thinking I shouldn't need to cut or disconnect any wiring (except the obvious between pump and diff) as the new diff will be locked before any signal is sent.? Being that the A-LSD is on the same circuit as the AWD I don't want to hack it and then get faults with the AWD ?
How do others do it ? What have you blocked off, cut etc?? (Nismoid)?
The Transfer case & rear diff pumps are all in the same cradle so easier just to leave them there and remove the lines which is what happened to mine.
I cant remember if the power feed for the A-LSD was disconnected. It's not throwing any failure lights, i know that much. I'll find out and report back next week.
cool, can you also have a look and see if they blocked off the line from reservoir in the boot or just the line from solenoid to diff?I should do a DIY when I do the swap for future reference.
    • Welcome. Dont let anyone dissuade you from your dreams. If you want a gtr, keep sabing and you will eventually get one. I feel like if I had have bought stocks, those companies would have gone bust and I would have lost my money.  There's a gamble in everything we buy. I've had good times and bad. But... I've also met my absolute best friend through this network and can't imagine life without them(more like a brother). Keep in mind, some specific mods will change as technology gets better. If you feel like general chat, there's always the wasteland.....
    • Those are some very cutesy barriers! Is that common?
    • Saw this abandoned Honda Fit in a carpark that was getting repaved... they just 'cut around it' and continued with the job! There's a number of reasons why the car could have been abandoned, but as for the construction company, legally they don't have permission to move the car from the owner (who has moved on and can't be contacted) so all they can do it just leave it there with enough space around it so it won't get damaged.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
