Hey guys im looking for rear pods for my r32gtr let me kno what u have . Ideally im looking for the n1 rear pod that goes with the side skirts , well thats what i think it is anyway, let me kno what u guys have , ill see if i can find a pic to go with the description . Thanks
https://www.sau.com.au/forums/topic/399771-r32-rear-pods/
