Hi,
Im chasing a bottom control arm from the rear suspension of a r34 gtt. It must be from a model with the alloy uprights becuase the ball joint is different. I need a ball joint, so it doesnt matter whether its a left or right arm, it comes out anyway. Preferably a bent arm that someone is happy to get rid of but can buy a straight one if the price is reasonable. Happy to pick up and pay cash in Melbourne.
The one I want is the arm that looks like this :
http://www.more-japan.com/files/d_6979.jpg
Thanks people
