Sau Vic 2012 Motorsport Championship Round 3 - Now With Entry Details
  • Replies 159
Posted Images
I sent a follow up email today and he said that I got in. Probably only just though.
Adz, How booked is PIARC? Do you know? Spewin I can't commit yet coz of work
As the family daily is back on the road, thought I best get working on the Nissan tractor for PI – thought the noise was from a leaking turbo gasket as per norm but this time it’s was different. The one piece dump/front pipe has cracked near at the turbo flange. Currently seeing if it can be welded otherwise left with the task of determining what no name replacement will line up with my cat - some shops are like, buy it, assume it will fit, we don't offer refunds.
One thing is certain, this time a flex pipe section will be going in!
I am in the final stage of organising a group buy on Hankook Ventus TD Z221 in 295/30/18 and 255/40/17s. Unless the group buy sells out quick then I doubt they will be ready before end of June :(
I'm interested in this group buy for the 255/17's, normal prices are under $400 a tyre in 17's which is better than the usual $2k+ for advans
Where do you get them for that price? Thats about what they are coming out at...if that is retail at a certain place then I will just buy them direct at normal price
The 21st of July was always on.
Martin is going to put the entry up here soon. I would suggest people get in quick.
Edit: i see the winton is back on. I hope they can get numbers.
I'm confirmed as in and driving an AWD.
Also got a notification of an AROCA Broadford for the 22nd July which I wouldn't mind doing but will be at the WRX PI on the same weekend so probably wont.
Guest
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
