Stock Stagea turbo dump pipe... unsure if it will fit the R33/34.. I think R33? may need to be confirmed
$20
..and still selling the stuff in my sig.
Edited by S T A R 3 3
For sale:
Standard RB20 Turbo - reasonable condition, some shaft play but still usable $50
T04e dump pipe flange + gasket (suit eBay turbo KLS Power Spirit, maybe others) $25
S13 front hubs, appear to be good condition, missing 4 wheel studs $40
Monza catch can, 1 litre, comes with fittings and hose brand new $30
Hey Guys.
Selling a few bars I have lying around
The top bar is a R34 Nismo S Type rear bar ready for paint
and the bottom bar is a R32 GTR front bar to fit a GTS-T also ready for paint.
$400 each ONO!
PM or SMS only to 0404543040
Thanks Bren
hey guys looking to sell my vp commodore wagon again sold it too a mate who then lost his license so i got it back, will only take a little bit to get roadworthy
needs two new front left wheel studs, rear view mirror bolted back on, could use a service and the wheels on it need new rubber
has roughly 317xxx ks on it is an auto and has been sprayed black
only looking for $400 (with the 18 inch chromes)
or $300 without (but you will need to bring your own wheels)
car is currently unregistered
i can be contacted on 0425416020 or [email protected]
cheers
hey guys i got some body kit for sale.
R33 GTR style front bumper (new) $350
R33 Side skirts $200 (used, black in colour in every good condition was on my car i pulled it out)
FMIC $100
O42l545387 Shiv
make me offer need them gone
Hi Guys,
Cleaning out my garage and I have found a heap of stuff I no longer require from old projects that changed direction
Brand New Parts still in boxes.
NISMO SR20DET Thermostat (21200-RS520) - $70
NISMO Big Operating Clutch Cylinder (30620-RSR40) - $140
GReddy Adjustable Camshaft Gear Sprocket (13523306) - $140
Please PM me if your interested in any of these parts
Edited by naughtyruski
The nismo clutch cylinder will also suit
  • Nissan Skyline BNR32 GTR (RB26DETT, 08/1989 - 01/1995) (Notes: 02/1993 - On, Pull Type)
  • Nissan Skyline BCNR33 GTR (RB26DETT, 01/1995 - 05/1998)
  • Nissan Skyline BNR34 GTR (RB26DETT, 01/1999 - 08/2002)
  • Nissan Stagea WGNC34 RS-Four (Series 1) (RB25DET, 09/1996 - 08/1998)
  • Nissan Stagea WGC34 RS-V (RB25DET Neo 6, 08/1998 - 10/2001)
  • Nissan Stagea WGNC34 RS-Four (Series 2) (RB25DET Neo 6, 08/1998 - 10/2001)
  • Nissan Stagea WGNC34 260RS (RB26DETT, 11/1997 - 10/2001)
Great for heavy duty clutches (larger bore)
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
