Set of Super Advan wheels black centres with blue outers.
17x8 35p with 225/45R17 nankangs with 75% tread
17x9 38p with 245/40R17 nankangs with 75% tread on the outside and 1% tread on the inside ;)
Open to offers or swap for a set of R32 GTR wheels. Located southside 0435 626 691
Just realised that I still have the low km's stock turbos off my GTR sitting in the shed.
They're in good nick, will let them go for a neat 100 bucks just to reclaim some scarce shelf space.
Do the PM thing if interested.
Got some EOIs to put up, figure might as well use this thread:
Samsung 24" FULL HD (1920x1080 resolution) LED PC monitor. As new condition, only about a year old anyway. Absolutely nothing wrong with it whatsoever. Very impressive monitor for something 'ordinary'. Has HDMI input.
$125 or best offer, will come with whatever cables you require with it (power, VGA/DVI, HDMI).
Dell 22" FULL HD (1920x1080 resolution) LCD PC monitor. Also as new condition, however it's a bit older than the Samsung. Absolutely nothing wrong with this monitor either, and picture quality/response etc is very good also.
$75 or best offer, will also come with whatever cables you require. Doesn't come with HDMI input though.
Both of these monitors are currently set up in my room and can be viewed in person should you desire. Reason for EOI sale is I'm looking at spending a ludicrous amount of money on a 46" LED TV to replace them with hahahaha
I'm also happy to set the monitors up for you should you require the assistance.
Let me see if I can find out for certain. I am after some for my car. Were these lower than stock hieght?
If they will fit my car I will grab them.
Not sure if they were lower than stock height. They came with the car so nothing to compare it too. Ill see if I can dig up some pics of when I bought it. May give u an idea? Ill measure them as we'll and post tonight.
fronts are 48cm
rears are 74.5cm
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
