A.c.t For Sale Thread
Shocks will bolt in. Only difference is rear strut top size is narrower on stagea. Unsure if the spacing between the mounting bolts is different. That and spring rates will be different.
Pehaps take a quick measure of the strut top and bolt spacing?
Then Denizer can measure his and BAM confirm/deny...
Edited by reaper1721
Ohh and i have a set of blue anodised wheel nuts for sale too! $10, comes with 2 key things. they are used, and the blue coating has come off some of them.
They were purchased here on the forums within the Business Trader section.. Taleb Tyres? Anyway, dont need them, went with silver in the end.
Hey guys I have a RB25DET head for sale it's got tomie valve guides valve springs and valve stem seals it's also been shaved a heap for higher compression and there was a 3mm head gasket used I don't know what it's worth so I'm going to say 600ono and I guess best offer gets it
please message 0410717935 if you want photos and if you want to pick it up I don't always check sau it will also come with a small box of bolts and timing belt cover and other bits and peices and a intake manifold
Edited by wilderboy
Anyone have RB26 GTR injectors for sale?
Need them ASAP! if i could borrow them for a day that would be even better!
also have a R33 Viscous diff for sale -150
and skyline Stock r32 Seat immacculate-80
Comes with free silvia seat! ;)
A set for all wheels or a set for one wheel?
I will have reasonably new set of 700cc Denso's (few thousand k's) out of my GTR on the 19th of this month, up for sale.
Well i need new tyres on the rear lol, they are only just off wear markers lol. What size RSR's do you have? Ill probably go 265s to match on the front but 285s would look awesome :P
Also that Case of bourbon is sitting here for you to pull my inlet manifold off and do the gaskets seeing as you will have heaps of experience after doing yours :D
Edited by k_d
If you go RSR's and your running 18x9.5 +12 then run 255's on the front.
If your offset is +15 or more then 265's maybe ok.
Beware of scrub on Drivers side FR when running anything greater than 255's with RSR's.
They are larger by 10% than other tyres and in my experience do scrub slightly on full turn going slow.
I onsold my new RSR 265's with this warning............and they scrubbed on the buyers car. SInce fixed I think ??
Oh righto. Yeah i wanted the flush look but decided against it, just for when i track it ill be less likely to tear a guard in an off track excursion lol
Gotta pull my front driveshafts out tomorrow and get them rebuilt, they wont last to sydney otherwise!!!
All mine are rolled too, did it before it got painted :P
Only rears for time being, wont have the $$$ for all 4 yet. Will be going same size on fronts though, aparently nissan have some ultra shitty 4wd system that never works and makes the car explode when using different tyre sizes :P
(yes i know you can have different widths as long as the rolling diameter is the same, im just shit-stirring :D)
I have a few things that I need to get rid of:
Set of R33 GTR V-Spec shocks with springs, were swapped at 55,000km for Tien Monoflexes, Perfect Condition, I think that a dust cover or two may have cracked - $150 ONO
2 Tail lights for R33 GTR in QM1 White, I think that the screw tab on one has snapped off, not sure if it makes a difference - $100 ONO
R33 GTR triple gauge cluster, was removed when it was replaced with a NISMO cluster - $50 ONO
R33 GTR ECU, working when removed - $30 ONO
Thats it.
Any questions sent me a text on 0FOUR23492200
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
