May be intetested in the suspension. How much lower is the V-spec suspension compated to stock? Is it like half an inch?
So stock is 5.7 inches and v-spec has 5.3 inches ground clearance, so not much in it, alittle firmer as well
Edited by Shuyin
A set for all wheels or a set for one wheel?
for the whole set.
edit: I must add that there are signs of wear on them, i used them a couple of times to and from the tyre shop, then bought plain chrome ones instead.
Edited by S T A R 3 3
Not sure I could go much lower than 0.5 inch at the moment anyway. My driveway is nearly straight up and I would smash my front lip if I did I think!
Let me see what I can swing in this months budget mate.
Cheers.
Cheers.
Sheeesh - you tip the girls at Sinsations $100 every friday night :P
I have a few things that I need to get rid of:
Set of R33 GTR V-Spec shocks with springs, were swapped at 55,000km for Tien Monoflexes, Perfect Condition, I think that a dust cover or two may have cracked - $150 ONO
2 Tail lights for R33 GTR in QM1 White, I think that the screw tab on one has snapped off, not sure if it makes a difference - $100 ONO
R33 GTR triple gauge cluster, was removed when it was replaced with a NISMO cluster - $50 ONO
R33 GTR ECU, working when removed - $30 ONO
Thats it.
Any questions sent me a text on 0FOUR23492200
Also have a set of brake ducts from a Series 2 R33 GTR going for $50
So is anyone after a rb26 head? I have one, its standard. Only downside is the cas half moon thingo is snapped off, i do have another std exhaust cam so i can swap them if need be. Pm me an offer. Not fussed if it doesnt sell tbh
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
