fs 1997 r33
173000ks have all recipts since i have owned the car plus some from previous owners serviced at 170000ks
mods :
g4 racing coilovers
jjr catback exhaust
fmic
turbosmart bov
genuine gtr wing
have stock exhaust and shocks to come with sale if needed
comes on 18" wheels
genuine gtr wing
starting price $8500
Mitsubishi Lancer, '00,
168xxx kms, AirCon, Power Steering, Automatic, CD/DVD/USB player (no screen), 17inch wheels with near new Federal Evo tyres.
Has a fair few bumps and scratches on the body from the previous owner but is mechanically good. Plates/rego are not included but should pass Roadworthy (can help out with rego).
$2700ono or a good box trailer + cash.
GTR Wing $200
ECU $150
Wiring loom $150
Side skirts $150
Rear bar $100
CD player surround $100
Shifter surround $50
Centre console $100
Front seats (minor tear on bolster) $150
Rear seats $100
Boot hatch $100
Tail lights $200
Door windows $150 each
Window regs $150 each
Aftermarket cat back exhaust $300
Coilovers $500
Engine $1000 (170,000 kms)
Diff $200
Rear adjustable camber arms $150
19" rims $1000
Turbosmart boost tee $70
Turbosmart boost guage $50
Aftermarket adjustable tie rod ends $100
Stock clutch $100
Flywheel $100
NISMO shift knob $50
Passenger front guard $100
Drive shaft $150
Starter motor $150
Alternator $100
Front and rear Brakes $400
Hubs $300
Prices are semi negotiable.
Hey guys, got my stagea up for sale so if you know anyone looking for their next import, please send them my way. Happy to work out some kind of reward for supplying a buyer.
http://www.skylinesaustralia.com/forums/topic/423732-1997-rs4-stagea-with-tasteful-mods/
Also selling a set of ADVAN RS wheels - 17x9.5+15 front and 18x10+25 rears.
http://www.skylinesaustralia.com/forums/topic/423983-advan-rs-17x95-18x10-wheels/
GTR Wing $200
ECU $150
Wiring loom $150
Side skirts $150
Rear bar $100
Centre console $100
Rear seats $100
Boot hatch $100
Tail lights $200
Coilovers $500
Diff $200
19" rims $1000
Stock clutch $100
Flywheel $100
Drive shaft $150
Starter motor $150
Alternator $100
Hubs $300
More parts available
Coil packs $150
Rear Lower control arms $120
Rear cradle $100
Front lower control arms $120
Seat belts $150
Door cards $100
Window switches $100 (drivers side) $75 (passenger side)
Side mirrors $100 each
Steering surround $50
AC control unit $100
Window wipers $40 each
Fuel flap $75
Fuel cap $20
Bonnet latch $75
Boot latch $50
Power steering reservoir $150
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
