So getting dicked around by people so selling it again (not so much here)
2x 30m rolls of window tint.
One is 35% tint 1.5m x 30m
The other is 15% Tint 1.5m x 30m
$200 it bought together or $150 each separately.
1997 WRX
121,000kms
1.5 way diff
Apexi and pedders lowered shocks
Hot dog exhaust
Turbo smart BOV
Turbo timer
3x HDI electric guages
Running stock boost
Sound system
Comes with BBS style 18" wheels and a set of stock wheels
Comes with 3-12 months rego depending on sale price
Best daily you can have while having fun on a cheap level.
$6500 or more with 12 months rego
Bren, managed to kill my hazards button over the weekend. Any chance you have one?
hey mate... not sure if you're still after a hazard switch.. i have a couple at home.. only the bulbs in them don't work.. only drama..
PM me if you are interested..
cheers.
Swap: I want to swap my s1 1993 gtst model for a series 2 stock gtst, nothing wrong with my car, it has full cream leather interior as well as cream leather dash, engine is at 96'000 genuine, amg rims, catback, aftermarket intercooler and radiator, looking to see if anyone has a series 2 stock they would trade!
Hi guys, doing a bit of a garage sale to clean out my shed a bit, got some parts leftover from old projects. Parts are located Southside ACT, I'm best contacted by SMS on 0404 303 954, I'm not very frequent on here but I try and check my PMs every so often. More pics available, just give me a buzz. Prices are pickup, happy to post at buyers expense, or deliver for a fee.
RB20/25/30 Engine parts:
- RB20DET silvertop forward facing plenum, deletes idle motor, factory cut n shut style, doesn't come with factory TB or sensors or anything $150
- Plazmaman FF Plenum, to suit RB30, as new unused condition. Comes with cold side cooler pipes, hoses and clamps, to suit XF TB, I paid $1160 new, after $800
- 6x VLT Injectors, 260cc, $150
- Various RB30E Injectors, $5 each
- RB25DET S2 CAS, ignitor, coilpack loom, $50 each
Pics of RB20 plenum:
Thanks guys,
James
hey guys ive still go a few things left over from when i stripped my 33.
hubs $250
intake manifold $150
control arms $50-70
passenger door missing window reg $100
clutch brake pedal plus master cylinders $200
cas $100
tail lights $130
most interior panels
jjr 3" stainless steel cat back exhaust $250
Edited by dd33
hi all i have allo of stuff lying around
serires 1 rb25det loom
intake manifold /turbo intakes
cam angle sensor
cam gaskets with half moon aswell
new water pumo thermo stat
timming belt
many vacum hoses heater hoses and radiator pipes
r32 power steer pump
33 engine mounts
and other hose clamps and shit like that
0431434808
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe will give me my power goals and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
