A.c.t For Sale Thread
For sale:
Greddy catch can. 1L capacity. - $50 SOLD pending pickup and payment.
HKS Super blow off valve with pipe (This is the first gen model). Suit Rb26dett. These are non flutter type (Just dumps the air in 1 go) Atmospheric. These are the high load BOV for use with more power -$100 for both with the pipe.
Standard RB26dett Injectors - $250. Also have fuel rail to suit if need be.
Standard R32 GT-R Airbox with new filter. $200 SOLD pending pickup and payment.
Boost controller $50 SOLD pending pickup and payment.
Also have Two apexi pod Filters (used) someone can have both for $50.
Also have stock cams for a 26dett as well.
Can get pics of the other items if people interested.
For sale is a R34GTT Nistuned ECU.
Comes with the ECU case plus the Nistune daughter board already installed by a Autotech in Hume. With teh daughter board installed up probably just need to tune it depending on what your running.
Nistune was tuned with exhaust and intercooler can be tuned to high hp applications. Selling because i have a standalone now.
$280
0417764194 or PM
Located in Canberra
oh and I have absolutely no spare parts left for R32 GTR's as of earlier today.
all Given away, Sold or dumped in the trash :banana:
I do however have a very clean garage :thumbsup: (not for sale :P )
Did he buy an ECU already ??
Edited by Sinista32
Also, I have some old EB games super banners ( The ones that take up the whole window space) for sale. I have the following:
Modern warfare 2
Battlefield 3
Bioshock 2
Splinter cell conviction
Gears of war 3
$10 per poster if people are interested.
Could try to get pics if you want :\
Updated list
- Apexi SAFC (Black) - $250 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Greddy Profec B Spec 2 boost controller- $300 used - SOLD
- wastegate actuator 12PSI w/bracket - $100 NEW - SOLD
- 5 bolt dump pipe - mild steel - $150 NEW - SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- Nissan R31 Skyline Wagon (Series 3) - $1200 ono - SOLD
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
Also have these to sell:
- Fender Stratocaster:
made: 1992-93
used but in good condition
looking for $600
- Yamaha RBX260
used, bought new, well looked after.
hoping to sell with 50W Peavey Microbass amp
Great starter package
Looking for $400 for both.
Can separate for the right price.
All located in Woden ACT
PM or Text: 0431900505
post-27427-0-75861400-1365816450_thumb.j post-27427-0-26886900-1365816453_thumb.j post-27427-0-49245900-1365816455_thumb.j post-27427-0-43758400-1365816457_thumb.j post-27427-0-43018900-1365816460_thumb.j
For sale:
HKS Super blow off valve with pipe (This is the first gen model). $100 for both with the pipe.
Hyosung GT250R $1200 with rego. Can PM pics if interested. See earlier post for details.
For sale:
Standard R32 GT-R Airbox with new filter. $200 (Back up for sale)
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
