Yeah I priced mine too high as I was unsure of Value and if I really wanted to sell or not but I was happy with the outcome. :yes:
It's a shame you are thinking of selling though Simon after everything and GLWS.
If you need a good daily, I have a nice R31 Wagon I may be willing to let go. :whistling:
Missing one Roofrack rubber. :laugh:
I haven't ben on here for a while, I didn't realise you'd sold the 33 Rob, sorry to hear :(
Its not the first time Ive thought about selling. I bought a lemon when I was younger and dumber, then spent the next 8 years spending 50K fixing and upgrading one thing after the next. I think I'm almost done (surely I've almost replaced everything)but with single income, wife and baby, the last few goals will take a long time to achieve.
I would really like to be able to participate in fun car things again, seems like its almost been 4 years since I was really able to.
Nobody will want it for the price im asking, so all this is probably pointless haha :)
I know 100% that before advertising the 31, there were 4 rubbers. I'm pretty certain that Jess got a little too carried away when helping with the pre sale cleanout :(
Also For Sale
R33 Gts-t factory airbox (no snorkel), few scratches etc, comes with K&N Filter element - $100
HKS SSQ Bov and RB adapter plate - $20, no idea on if it works
Standard R33 Gtst Side mount cooler (core only) $25
All located in Banks
Any gamers out there?
I bought an oculus rift dk2 a while ago.
Have gotten what i wanted out of it - see what the talk was all about and decided i want to buy the consumer version once it's out.
I have used it for a few hours and there is a small scratch on one of the lenses but you can't see it.
Can supply photos/answer questions for anyone interested.
Looking for $400
Cheers!
Have an Ogura twin plate clutch here with plenty of meat left on it still. Not using it anymore as I've gone to a quad plate.
Suitable for an R32 GTR.
Don't have the bearing from the centre but they're not that expensive or hard to get. $400, prefer local sale.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
