18" DEEP DISH Manaray Sport VRS Wheels. Offset 35.
Looks great on imports, and wild on Skylines.
Rears run 265's and fronts 245's
Tyres are finished.
Usual gutter rash, and a little clear coming off but nothing that would stop you from buying them.
Pick up only from Queanbeyan.
$300
SemiSlick / Road Tyres. Potenza Adrenalin RE002 245/40/18 X3.
Amazeballs tyres.
2 Really good with heaps of tread, 1 half tread worn.
Only selling as one was slashed, and I just bought a whole new set.
Won't separate, take the 3.
Grab a bargain!
$200
Bellona Rims 19" with 2 almost brand new tyres. 19x8. Offsett 43.
Buy tyres get free rims! 2 tyres 245 / 40 / 19
One rim hit a pothole but is fixable. Was quoted $220 - cheaper if you take the tyre off. Bit of clear coat coming off.
Looks Baddass on a big car.
Usual gutter rash.
$300
Boost Tees:
Regular $25 Posted or pick up Queanbeyan and a free beer.
High Boost Tee from Turbo Tech. From memory it was good for 30psi or there abouts. (Doubt anyone would do that though, but anyhoo)
$35 Posted or pick up in Queanbeyan and a free beer.
Tyres are finished.
$300
SOLD
Amazeballs tyres.
Grab a bargain!
$200
SOLD
Pair of 15x8 40p with 275/60r15 M&H Drag Radials should fit most skylines with rolled guards $750
Sponsor me these and you can both probe my chambers
Guys I'm moving to the UK so getting rid of everything at rock bottom prices.
ORC 559 twin plate clutch. heaps of meat. but needs a new throw out bearing...cause its gone missing.
heaps of meat $400.00
GCG td06-20g bolt on rb20/rb25 turbo. complete with all lines and fittings
used for less than a hour before the head lifted. this is the first one gcg sold and its awesome. matches their high flow but everything is new!
I paid 1425 + freight
its yours for $1100.00
Haltech E11v2 r32/r33 plug in ecu and 3 bar haltech map sensor. This has been in the club forever. was on sins gtr. then owned by tats and shell, then I bought it
$600
Xspurt 1000cc short injectors in an aeroflow rail and turbo smart FPR1200 regulator. This is setup to go under the factory rb25 plenum
its about 6 months old and comes with a loom to fit r33 rb25s. I paid 1300ish
I would like to swap it for some factory injectors and rail plus + $600 cash.
photos and more details to follow.
best to pm me. not really open to offers because its cheap as shit already.
cheers
Andrew
Also selling the beloved car. didn't think id ever sell this thing.
but as above an opportunity to move the uk has come up and cbf dealing with a car sitting here.
so 93 mod R33 gtst
Pretty rough around the edges. and it will be sold as a near stocker unless you want to buy it with all the above parts.
its getting a new head gasket and arp head studs currently. bores look pretty good and can provide pics if needed. I'm not reusing any of the under plenum hoses, Just waiting on an order to arrive from Amayama, all gaskets will be replaced with Genuine Nissan items.
Has BC BR coilovers, r33 GTR seats, a blitz turnflow front mount, fresh "race brakes sydney" rotors and pads front and rear, 80mm momo corsa exhaust and 3"front/dump pipe. Genuine Sparco 17x9" wheels with Federal 595 RS-R tyres with 70ish % tread and some sort of Exedy HD clutch.
ACT rego until Feb
I can't believe I'm doing this....
but
$3k come get it
Best to get me via pm and I'll shoot you my number
but yeah. keen to sell. gotta come up with 10k before July...so buy my junk!
12278802_10153259539731699_3728534172914
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
