A.c.t For Sale Thread
R32 GTR cradle no hubs/brakes/diff or driveshafts. Has a HICAS lock bar and knuckles. $100
R32 GTR rear struts with king springs. One has damaged thread on top of the shock. $80
Still got the R32 GTR HKS Drag rear coilovers $300
FJ 720 do you still have the HICAS lock bar on the R32 rear cradle?
K&N panel filter for RB26DETT part no. 33-2031-2. Used for approx. 20k. Includes new bottle of power kleen and almost new can of spray oil (only used once for initial light coat). $80 ono.
I've got a couple big opportunities coming up at the end of the year plus looking to work overseas for 12 months so I want to free a few things up...and loose the desire to constantly buy more car parts hahah
price drop $60
Walbro 400l fuel pump did less than 500km, come with wiring and new strainer $50
Rb30 fuel rail new with an6 and an8 fitting also to suit 14mm or 11mm injectors with adaptors all included $150
Rb25 candy blue rocker cover $250
Rb25 clear cam cover used still in good condition just needs a good clean $50
Rb25 head with stock cams stock valve spring etc but no valve seals or rocker covers $100
Rb30 head $100
Rb25 block with blown piston ring $100
Rb30 block $150
Rb25 S1 afm $50
Rb25 S1 Throttle body and throttle position sensor $60
Rb25 stock fuel rail with stock injectors $50
Rb25 injector loom $40
Wouldn't happen to have a decent condition rb30e harmonic balancer for r31 hanging around?
Rb30 head $100
Rb30 block $150
Rb25 S1 afm $50
R31 RB30 harmonic balancer are normally single piece while VL RB30 harmonic balancer are two piece as Shiv pictured. However I have seen two piece on a R31 before.
The Rb30 engine i have came out of a R31
Can you post up a pick of the side of the thing, if I can see if it has ribbed belts or v-belts it will give me a better idea (my rb30 has ribbed)
Looks similar to mine except mine is a single piece (and, um, has a massive chunk missing out of it):
rb30e%20harmonic%20balancer.jpg[/url]
rb30e%20harmonic%20balancer2.jpg[/url]
Anyone know if these would be interchangeable?
Edited by dorifticon
bump make an offer guys
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
