  On 18/10/2015 at 6:40 AM, FJ 720 said:
R32 GTR cradle no hubs/brakes/diff or driveshafts. Has a HICAS lock bar and knuckles. $100
R32 GTR rear struts with king springs. One has damaged thread on top of the shock. $80
Still got the R32 GTR HKS Drag rear coilovers $300
FJ 720 do you still have the HICAS lock bar on the R32 rear cradle?
  On 18/01/2016 at 4:25 AM, cpark said:
K&N panel filter for RB26DETT part no. 33-2031-2. Used for approx. 20k. Includes new bottle of power kleen and almost new can of spray oil (only used once for initial light coat). $80 ono.
price drop $60
Walbro 400l fuel pump did less than 500km, come with wiring and new strainer $50
Rb30 fuel rail new with an6 and an8 fitting also to suit 14mm or 11mm injectors with adaptors all included $150
Rb25 candy blue rocker cover $250
Rb25 clear cam cover used still in good condition just needs a good clean $50
Rb25 head with stock cams stock valve spring etc but no valve seals or rocker covers $100
Rb30 head $100
Rb25 block with blown piston ring $100
Rb30 block $150
Rb25 S1 afm $50
Rb25 S1 Throttle body and throttle position sensor $60
Rb25 stock fuel rail with stock injectors $50
Rb25 injector loom $40
Wouldn't happen to have a decent condition rb30e harmonic balancer for r31 hanging around?
Rb30 head $100
Rb30 block $150
Rb25 S1 afm $50
  On 08/02/2016 at 4:14 AM, StinkyPoo said:
R31 RB30 harmonic balancer are normally single piece while VL RB30 harmonic balancer are two piece as Shiv pictured. However I have seen two piece on a R31 before.
The Rb30 engine i have came out of a R31
  On 08/02/2016 at 2:05 AM, dorifticon said:
Can you post up a pick of the side of the thing, if I can see if it has ribbed belts or v-belts it will give me a better idea (my rb30 has ribbed)
Looks similar to mine except mine is a single piece (and, um, has a massive chunk missing out of it):
rb30e%20harmonic%20balancer.jpg[/url]
rb30e%20harmonic%20balancer2.jpg[/url]
Anyone know if these would be interchangeable?
Edited by dorifticon
bump make an offer guys
