I have a queen sized bed (nice wooden frame) and mattress for free if anyone wants.
About 10 years old. We've upgraded to a king size.
Would make a good bed for someone's spare room.  Alternatively it'll be going to the tip/green shed.
  • Like 1
Mattress collection costs a bit too. If it's in reasonable cond no worries but if it glows under a blue light ..... well :P
or you can ditch it or I can drop it off at the mattress recycling for the good deed.
Edited by Sinista32
On 18/01/2017 at 5:31 PM, LTSJayce said:
FREE to a good Skyline home. R32 GTS front seat, as pictured. All you have to do is come and pick it up. Located southside. IMG_1484721029.513903.thumb.jpg.93fed1aeIMG_1484721048.420832.thumb.jpg.94184471
Me Me Me!
I'll take it please if you still have it.
Thanks,
James
Look to sell my set of New Bride Replica seats that I purchased a few years back in a group buy.
Haven't installed them, just been stored like in my garage.
They come with universal rails that will need drilling to probably fit.
$600 ono
Hit me up on here with a message if you're interested
Thanks Jayce. Great to meet you.
It is 100% an R33 GTR passenger seat that has been retrimmed. I measured it and is the same as in my GTR.
Ah! There ya go! I learned something! Pleasure to help out, either way!
$600 ono
Sold :)
  • 1 month later...
180sx and R32 Parts
Canberra pickup, can post smaller items.
180sx/s13:
- $80 Stock s15 manifold with metal gasket
- $60 Stock Sr airbox
- $60 Stock Sr sump
- $20 steering column surround
- $50 Mirrors (one missing glass)
- $10 Non abs front hub
- $10 Ciggy lighter
- $60 GKtech pod filter
- Random interior plastics and trim
R32:
- $120 Rear seat
- $100 Pod filter box
- $75 Radiator cooling panel
- $30 each, Front door cards
- $30 each, Rear door cards
- $20 Passenger kick panel
- $25 Glove box
- $20 Front mats
- $20 Underside drivers dash (small crack)
- $20 Cluster surround (small crack)
- $80 Front indicators (drivers cracked)
- $50 blitz bov
- $30 coolant temp sensor /w adapter
- $150 hydraulic carbon fibre bonnet struts (new)
- Random trim bits
Also have a box of belts for s13/r31 and probably more. Free with any purchase.
Make an offer, need all of it gone from the garage!!!!
Might have more parts just text me as im not on here much anymore
0416 276 617
  • 4 weeks later...
Hi all,
Have been dormant on SAU for ages, but as my R32 build progresses I'll be selling a lot of parts. GTR seats, Nismo seat covers, Veilside wheels etc all coming up shortly).
Should still be a few old heads on here who can vouch for me (amazing to see my sticky threads are still here, too, from a thousand years ago).
First up is the front and rear bar. Genuine items and I believe they're the originals (Nissan logo is stamped into the backs of them). Both are in very good condition for their age, with just the usual small nicks and swirl marks, but overall they're fantastic. The one exception being the drivers side of the front bar, which I brilliantly scraped along a concrete pillar, meaning you'll probably want to have it touched up professionally.
I've attached a couple pics of the car with the kit on, so you get a proper idea of what they look like on.
Also have a JUN carbon fibre front skirt, which attaches to the bar. Not sure if this is genuine JUN, but given that it appears to be carbon over an FRP base, I'd have to think it's not genuine JUN. Hard to know. Overall it's in great condition, with the exception being a few small pressure cracks in the clear coat from scraping speedhumps (have included photos where possible).
I'm way out of touch with the parts market, so I'm guessing on pricing. I guess if it's too high I'll end up having to bring the prices down. Too low and someone gets a good deal.
Front Bar: $400
Rear Bar: 300
Front Lip: $300
It's also worth noting that I'm both mechanically and technically useless, so I'm probably not going to know the answers to any even remotely obscure questions about the kit.
Collect from the inner-south.
Cheers,
Andrew.
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
