Ok so im running out of space at my place so am selling all the stuff that i have pulled off the gtr since iv had it. this includes all the twinturbo crap, the only things you would need is turbos and water/oil lines, maybe a few nuts and stuff, but all the piping and exhaust stuff is there. pm me if interested.
Also have K's pods to suit gtr, bolts onto the afms. $80
I also have a spare plenum to suit gtr, no throttles or anything, just the plenum. $50
Standard GTR fuel rail. $40
2x Standard fuel regs $20 each
2x GTR Bov's. will only sell as pair. Pm me an offer.
poope you are no fun. i need a bit of stuff as previous owner hacked away at mine to add the atmos ones i have. Car will be going into ultimate tunes soon anyway to get a bit more done so ill take a proper look as to what i need when the front bar is off haha
4 SSR MK1's
Offset: +11 (Type B)
PCD: 4x114.3
Price: $650
Comes with a set of new shank nuts and washers to suit toyota wheel stud thread.
Since I got these I pulled out all the rusted nuts and bolts for the wheel centres and put new ones in.
One rim has a minor dent on the outer lip. Wicked wheels out in qbn should be able to fix it real cheap if you don't want to have a crack your self. If I get it fixed I will be asking a lot more for them.
These are great rims for an old school look and your missus can use them as a mirror to do her make up.
Edited by azathoth
I have some parts lying around forsale
Genuine GTR Door Sills - $250
Please pm if interested
So found out they are for a R34 GTR....
Going to put up on eBay pm if wanting this.
Edited by ScR33m3r
Series 2 R33 Front bar indicator/fog light combination
White lens covers,
Electrics work fine.
Light scratches from moving around on lens covers but easy to sand and paint over.
$180 ono
Pm if any questions or anything
R33 GTR Carbon fibre faced gauge din set.
Brand new been sitting around for a while
$250 ono
Pm any questions or anything
R34 GTR Door scuff Sills
Brand new
Thought they were for a R32 but didn't fit either R32 and R33
$250 ono
Selling helga 96' R33 Skyline GTST - Have advertised on for $4250 with a decent amount of interest. I wouldn't want to go below $3,000 ono. as the car works perfectly fine and drives straight, pits just failed the chassis (among other minor things) - Can be registered in NSW, rego runs out 4th of May 13'. Not sure if I'm asking too much for $3,000 for SAU members but a starting price has been given. Cheers
interested in a 68 hilux?
plus a little cash your way?
needs paint attention, but mechanically very good.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
