fs 1997 r33
173000ks have all recipts since i have owned the car plus some from previous owners serviced at 170000ks
mods :
g4 racing coilovers
jjr catback exhaust
fmic
turbosmart bov
genuine gtr wing
have stock exhaust and shocks to come with sale if needed
comes on 18" wheels
genuine gtr wing
starting price $8500
Mitsubishi Lancer, '00,
168xxx kms, AirCon, Power Steering, Automatic, CD/DVD/USB player (no screen), 17inch wheels with near new Federal Evo tyres.
Has a fair few bumps and scratches on the body from the previous owner but is mechanically good. Plates/rego are not included but should pass Roadworthy (can help out with rego).
$2700ono or a good box trailer + cash.
GTR Wing $200
ECU $150
Wiring loom $150
Side skirts $150
Rear bar $100
CD player surround $100
Shifter surround $50
Centre console $100
Front seats (minor tear on bolster) $150
Rear seats $100
Boot hatch $100
Tail lights $200
Door windows $150 each
Window regs $150 each
Aftermarket cat back exhaust $300
Coilovers $500
Engine $1000 (170,000 kms)
Diff $200
Rear adjustable camber arms $150
19" rims $1000
Turbosmart boost tee $70
Turbosmart boost guage $50
Aftermarket adjustable tie rod ends $100
Stock clutch $100
Flywheel $100
NISMO shift knob $50
Passenger front guard $100
Drive shaft $150
Starter motor $150
Alternator $100
Front and rear Brakes $400
Hubs $300
Prices are semi negotiable.
Hey guys, got my stagea up for sale so if you know anyone looking for their next import, please send them my way. Happy to work out some kind of reward for supplying a buyer.
http://www.skylinesaustralia.com/forums/topic/423732-1997-rs4-stagea-with-tasteful-mods/
Also selling a set of ADVAN RS wheels - 17x9.5+15 front and 18x10+25 rears.
http://www.skylinesaustralia.com/forums/topic/423983-advan-rs-17x95-18x10-wheels/
GTR Wing $200
ECU $150
Wiring loom $150
Side skirts $150
Rear bar $100
Centre console $100
Rear seats $100
Boot hatch $100
Tail lights $200
Coilovers $500
Diff $200
19" rims $1000
Stock clutch $100
Flywheel $100
Drive shaft $150
Starter motor $150
Alternator $100
Hubs $300
More parts available
Coil packs $150
Rear Lower control arms $120
Rear cradle $100
Front lower control arms $120
Seat belts $150
Door cards $100
Window switches $100 (drivers side) $75 (passenger side)
Side mirrors $100 each
Steering surround $50
AC control unit $100
Window wipers $40 each
Fuel flap $75
Fuel cap $20
Bonnet latch $75
Boot latch $50
Power steering reservoir $150
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
