Fj 20 engine and numerous parts for sale
Engine is in pieces at the moment
Would like to sell whole but will separate
Standard t3
Blow off valve
Standard injectors $50.00 each
550cc injectors $85.00 each no need to drill out injector
Plenum $100
Sump $ 100
Head $ 250
Wisco pistons $50 each
Standard internals
Will sell whole engine $ 500
Will not ship must be picked
For Sale:
Rb26 engine out of r32. 107xxx kms.
new genuine water/oil pumps replaced less than 1500kms ago
new dayco timing kit at same time.
standard everything except nitto throttle body gaskets
comes with all inlet gear except injectors.
Nothing on the exhaust side
will come with sump (no diff in it though)
will come with clutch ( its pretty shagged though)
Lifters are very noisy when motor is cold, goes away once warm. You are welcome to inspect/comp test. motor is still in car and running until saturday.
Pm me
  On 21/05/2013 at 1:33 AM, Sinista32 said:
any chance any of you really great awesome guys have some sun visors for me please.
It's for my 32 but 33's may fit also.
Got some R33 ones if you want Riktard
  On 21/05/2013 at 11:51 AM, Shaynesspk26 said:
Fs hypergear Atr43g .63 turbo kit comes with turbo high mount manifold 3" exhaust from turbo to cat braided lines and turbo smart external wasit gate $800
I might want it.
For rb 25? 20?
How much use has it had?
Any pics?
Hi guys I'm selling my car audio gear including custom boot set up for an r33 including custom box 12inch clarion sub and clarion amp plus to jl audio splits all top of the line gear if your interested please msg me and i can send pics and other details. 0457133010 cheers
Stripping S2 R33 Parts
Prices are negotiable.
GTST wing $150
ECU $150
Wiring loom $150
Side skirts $150
Rear bar $100
CD player surround $100
Double din CD/DVD player (alpine) $400
Shifter surround $50
Centre console $100
Front seats (minor tear on bolster) $150
Rear seats $100
Boot hatch $100
Tail lights $200
Skyline rear centre garnish $100
Door windows $150 each
Window regs $150 each
Aftermarket cat back exhaust $300
Coilovers $500
Engine $1000 (170,000 kms complete no turbo or bolt ons)
Diff $200
Half shafts $100 each
Rear adjustable camber arms $150
19" rims $1000 with brand new tyres
Turbosmart boost tee $50
Turbosmart boost guage $50
Aftermarket adjustable tie rod ends $100
Stock clutch $100
Flywheel $100
Passenger front guard (perfect condition) $100
Tail shaft $150
Starter motor $150
Alternator $100
Front and rear Brakes $400
Brake rotors $200
Hubs $300
(SOLD) - Coil packs $150
(D/S SOLD) - Rear Lower control arms $60 each
Rear cradle $100
Front lower control arms $70 each
Seat belts x 4 $150
Door cards $100 each
Window switch elects $100 (drivers side) $75 (passenger side)
Window switch surrounds $100 each
Side mirrors $100 each
Steering surround $50
AC control unit $100
Window wipers $40 each
Fuel flap $75
Fuel cap $20
Bonnet latch $75
Boot latch $50
Power steering reservoir $150
(SOLD) - TPS $50
Top AC vents $20 each
Passenger side headlight $150
NO FRONT BAR
NO INTERCOOLER or PIPING
NO TURBO
Still left over.
Also have a heap of mint condition I interior parts.
Still left over.
What rims are they? Widths, offsets etc? Got any pics?
I'm in the market for some new rims... :D
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
