Whatever Jezz offers, I'll go $20 higher!
Jks :P
That would be fun, stock r34 turbo alright at 12psi?
Haha IHY !
Yeah R34 can run 14PSI (Safe) from what I've been told. 12PSI is a nice middle point.
rofl that R31 wagon is tempting, but it's a bit exxy for something that'll wind up against a tree/boulders LOL
$1200 ONO
Perhaps you'd like to suggest a more tree/boulder smashing appropriate price? heh
Jks :P
Orly? haha
For sale:
Greddy catch can. 1L capacity. - $50 SOLD pending pickup and payment.
HKS Super blow off valve with pipe (This is the first gen model). Suit Rb26dett. These are non flutter type (Just dumps the air in 1 go) Atmospheric. These are the high load BOV for use with more power -$100 for both with the pipe.
Standard RB26dett Injectors - $250. Also have fuel rail to suit if need be.
Standard R32 GT-R Airbox with new filter. $200
Also have an old boost controller with everything for $50. It's an original Profec-b like this one seen below:
Also have Two apexi pod Filters (used) someone can have both for $50.
Also have a set of original Cams in decent condition. Can make an offer if you like.
Can get pics of the other items if people interested.
Edited by Anfanee
Haha IHY !
Just coz the turbo will push 14psi, doesn't mean the ECU will allow it ;)
Disclaimer: I have no idea when R&R kicks in on stock R34 GT-T ECU.
$1200 ONO
Orly? haha
haha sub-$500 (and that's only if I'm going halves with someone lol). Wouldn't wanna defile a half-decent car though.
It's too nice to break, would be sad to see it ruined...
All proceeds go towards getting the toy car running again though!
  • Like 1
Yeah exactly. Would need to be a banged up shitter with barely any rego (and maybe even a slim chance of it being able to get more haha).
Also thinking of selling my 250cc Hyosung. Runs perfectly, has brand new brake pads and front tyre. The fairings are rubbed back to paint, and the seat will need replacing at some point. Only needs rear tyre to pass RWC. looking for $1200. PM me if interested and ill take some photos.
For sale:
Sent you a PM RE: boost controller.
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
