Rob, side winkers - clear?
No, stock Orange and a pair sprayed with Smokey Paint.
Kasko Bought my Nismo-ish Smoked Clears, perhaps he will sell them too you as the 33 is out the door.
These fit?
They are the std ones in a Nismo box.
And i have about a hundred of these tins, they are metal with a plastic lid that seals fairly well.
Good for nuts and bolts etc....
Take as many as you want, people.
Edited by D.I.Y. Mik
For sale:
HKS Super blow off valve with pipe (This is the first gen model). $100 for both with the pipe.
Standard RB26dett Injectors - $220 Price drop
Standard R32 GT-R Airbox with new filter. $170 Price drop
Also have Two apexi pod Filters (used) someone can have both for $50.
Hyosung GT250R $1000 if it sells this weekend. Still has rego. Runs perfectly.
Also have stock cams for a 26dett as well.
Can get pics of the other items if people interested.
yeah i am and still want to want to run plumb back i hate atmo's. so i thought gtr one would be a good bolt on upgrade. i heard they sound more agressive but that may be the GTR placebo effect
They sound a bit more Agressive but still muffled by plumb backness.
If using the Stock airbox it's a little louder, with a pod it's a tougher "Whoopishhhhh". :D
Supposedly will hold higher Boost pressure than a stocker.
  • Like 1
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
