Brand new OEM centre vents. Suit R32 (a lighter grey). Most likely GTS-t
Could paint black if you have the black stereo surround for GTR
Yours for the low price of $70 (normally $149)
I need dark grey :/
barmp
For sale:
HKS Super blow off valve with pipe (This is the first gen model). $100 for both with the pipe.
Standard RB26dett Injectors - $200 Price drop
Standard R32 GT-R Airbox with new filter. $150 Price drop
Also have Two apexi pod Filters (used) someone can have both for $50.
Hyosung GT250R $1200 for SAU members Still has rego. Runs perfectly. Rubbed back for painting fairings. Only needs rear tyre to pass rego.
  On 06/12/2013 at 3:09 AM, StinkyPoo said:
I have lots of space, happy to pick them up instead of them going into a bin.
  • cuong nguyen has pmed me saying hed like the shocks but if he doesnt end up taking them you are welcome to come grab whatever you want.
I also have a pair of 17" rims that are just sitting around doing nothing. Pretty sure they are either 8.5" or 9" wide and suit either front or rear gtst offset. Can get pics and more details if anyone is interested. Actually i think if you look back through one of my for sale threads i was trying to flog them off a while back.
Anyway they are also free now if anyone wants them. Could be good for skids or track wheels...
have R33 parts -boot lid $50 and interior - seats and centre console $20 each, rear wing $30., rear tail lights $50 . fuse boxes, rear drive line and arms.. master cylinder $50 other odd bits.
have pink label afm and apexi pod filter all as one piece $70 can separate.. r33 gtst ecu $150
R33 stock clutch heeps on it $100.. r33 exhaust cat back with cannon from dump was 90db on my car and flowed 320kw no restrictions.. $200ono
pls pm me as i dont check back here often.
BUMP
- Apexi SAFC (Black) - $250 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Greddy Profec B Spec 2 boost controller- $300 used - SOLD
- wastegate actuator 12PSI w/bracket - $100 NEW - SOLD
- 5 bolt dump pipe - mild steel - $150 NEW - SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- Nissan R31 Skyline Wagon (Series 3) - $1200 ono - SOLD
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
  On 10/12/2013 at 5:02 AM, MANG said:
BUMP
- Kinugawa TO4E oil drain - $50 NEW - SOLD
Cheers
Simon
Noooooo, don't sell my SAFC!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
