Mostly 31 stuff :)
HR front struts and r31 rears - $350
Will come with the king springs, new rear monro GT's and HR brakes. brakes will need a rebuild
Set of 4 18x8 ROH Adrenalin to suit S14 with federal 595s, 90% tread left - $400 ono
4x 4/5stud, 17x7 with Achillies ATR sports 95% tread $400ono
4 Passage rims, 2 shit tyres - $200ono
4x 17/240 Federal FZ101 medium compound - $250ono
about a year old, 6 odd track days
4 stud space saver -$50
2x s13 tear drop rims - $50
2x 14x6 hotwire rims - $50
extractors $70
mspec radiator. 2 core - $50
Rh hotplate average - $20
S3 headlights - $50 each
cam cover - $10
Nissan cover sold.
Wiper stalks $5
Light/indicator stalks$5
HR31 castor rods with urethane bushings - $50
R32 GTST wing purple - $150ono
HR31 wing - black - $50ono
HR31 Rear brake calipers with near new pads - $100ono
5x Federal Couragias, 30/9.5/R15 - $200
One was a spare full tread, rest are about half worn
:( I don't need any of it.
Wheels = sorted, shocks/springs = sorted (although lower would be good), extractors in Transit etc...
need a 2.25" exhaust (to suit Wagon) and a KA24 Throttle Body though. :whistling:
  On 08/11/2013 at 4:34 AM, dd33 said:
intake manifold (with injectors and fuel rail )
both rear lower control arms
clutch brake pedal plus master cylinders
cas
tail lights
fuel pump
adjustable front tie rod ends
take the lot for $150
s2 r33 front seats $100 for both
will take $80 for the seats or will do a front and rear seats plus door cards for $250ono plus what ever 33 interior parts i have laying around
$120 ono for what you see in the first pic
Works wheels are sold.
R34 cold air box, r33/34 front mount and piping and turbosmart bov all still for sale.
Leaving town in a few days and would rather have some extra cash for the move than have to leave it at my old mans.
I sent u a few pm's but no reply, when can I look at the cooler kit?
Found a brand new coolingmist water meth system and resovoir in the shed today. Was going to put it on the 33 before I sold it and the evo is dual map tuned so no use for it now.
If theres any interest I can get pics etc...
R34GTT TURBO FOR SALE
OP6 TURBO
Turbo is in good condition it was taken off to install another turbo. Shaft play is still withing allowable tolerances. Came off my current engine which has done 115000kms.
$280
0417764194
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
